IP revoked? - Team Camaro Tech
post #1 of 2 (permalink) Old Aug 15th, 12, 09:54 PM Thread Starter
JIM
IP revoked?
Every other day or so I keep getting messages saying my IP has been revoked. Then a day or tow later it lets me back in like normal-just like now.
Also...when I try to send messages to mods it has me fill out all the stuff...answer the secret squirrel question..and then says the message wasn't sent and it takes me right back to the start? Just an endless loop..
Any ideas?
Thanks,
JIM
'67 Vette Pump gas all motor 540", GForce 5 Speed
Dana 60 IRS-3.07 gears
540Hotrod is offline
post #2 of 2 (permalink) Old Aug 16th, 12, 05:17 AM
69-Pace's Avatar
Re: IP revoked?
JIm - How are you connecting your pc to your network?
If you are using a home router issuing DHCP addresses it sounds like your settings for "lease" of the ip address expire and get revoked to the be put back in the pool. The machine then would either need to request a new IP address from the DHCP pool - in windows systems using the repair connection tool or manually using ipconfig /renew. Or reboot the machine.
You can change the setting to maintain the lease forever or assign an ip to your full time machine.
As to the messages...you sending through the PM option here, or an email message
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
