Unable to use "back" button - Team Camaro Tech
post #1 of 5 (permalink) Old Oct 9th, 12, 07:43 PM Thread Starter
67LSRS
After upgrading to IE 9 it appears that after im in the forums for awhile or when browsing searched criteria, the "back" button seems to quit responding. Anyone else experiencing this or do I have something going on with my PC?
_____________________________________________
My 67 RS Project:
LS1, FAST XFI 2.0, Turbo 350, 12 Bolt 3.73's.
67LSRS is offline
post #2 of 5 (permalink) Old Oct 9th, 12, 09:51 PM
Re: Unable to use "back" button
I'm not using IE 9 yet and I still have this problem. If you click the little arrow next the the "back" button it shows where you have just recently been. I always have at least two "google adds" in between where I am and where I want to go back to. If you bypass the google adds that way, you can go backwards. Sorry, not sure what cause is or what the fix is, but it's not just you. Hopefully someone "in the know" will be able to help.
Fyne69 is offline
post #3 of 5 (permalink) Old Oct 10th, 12, 04:14 AM
Guess
HwyStarJoe's Avatar
Adblock+
http://adblockplus.org/en/
You'll never miss what you're missing!
HwyStarJoe is offline
post #4 of 5 (permalink) Old Oct 10th, 12, 05:14 AM
69-Pace's Avatar
Yes several sites including google services use javscripting tools that refresh you right back to their page. The NO SCRIPT add in for firefox works very well at killing all sorts of browsing pests. I don't use IE for anything other then work related applications.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 5 (permalink) Old Oct 10th, 12, 08:11 AM
DjD
DjD's Avatar
Searches do expire because new posts can come along during the time you search and that will make the back button not take you back but there should be a message letting you know the search timed out. If that's not the case case it might be ad.click stuff and if you click and hold the back button you will see the ad.click links. I don't think that is what you are seeing because I tried viewing the forums after logging out and didn't find any ad.click links and my back button worked fine.
Test to be sure it's happening on other sites as well and if so start looking at all the tunable settings, the new browser probably got defaulted to a different setting when you configured it after the upgrade...
...Dennis
DjD is offline
