Quotes / subscriptions? - Team Camaro Tech
 1Likes
post #1 of 28 (permalink) Old Mar 6th, 16, 11:02 PM Thread Starter
Kurt S
Kurt S's Avatar
With the changeover, the default for subscriptions changed *and* I got subscribed to every thread I ever posted in.
I fixed both of those (took a while to see I didn't want 'no email'), but now I'm getting notified every time someone quotes me. How do I stop that??
I have zero subscriptions, so the quote notifications doesn't appear to be tied to that.
Kurt S.
CRG -
Kurt S is offline
post #2 of 28 (permalink) Old Mar 7th, 16, 03:40 AM
Re: Quotes / subscriptions?
User CP, down the left column to edit options
Opt out, limit what you get, ETC.
68 Camaro~LSx ~all motor
post #3 of 28 (permalink) Old Mar 7th, 16, 06:20 AM
Brent
67Rally's Avatar
I noticed the same thing. I was going to try to stop that as well, but I think it's actually a good addition.
If someone quotes you from an old thread, they may be hoping for a response from you, or clarification of some info. With the old system, unless you were subscribed to a thread, you would never know if someone was waiting for a response, unless they PM'd you.
67Rally is offline
post #4 of 28 (permalink) Old Mar 7th, 16, 01:23 PM
Administrator
John Doe
Hey there,
Has Doug's suggestion helped you solve this issue?
Let me know if there is anything else I can help with.
Richard.
Administrator is offline
post #5 of 28 (permalink) Old Mar 7th, 16, 05:25 PM Thread Starter
Kurt S
Kurt S's Avatar
OK, maybe it's staring at me, but I don't see anything about Quote Notifications.
Messaging & Notification - seems like a likely spot, but I see emails, subscribing, PM system, and Visitor messages.
Thread Display Options - nope
Date & Time Options - nope
Miscellaneous Options - nope
Kurt S.
CRG -
Kurt S is offline
post #6 of 28 (permalink) Old Mar 7th, 16, 05:38 PM
69-Pace's Avatar
No there is no option that I have been able to find. I am also no subscribed to a million threads even though my preference says no.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #7 of 28 (permalink) Old Mar 8th, 16, 08:29 PM Thread Starter
Kurt S
Kurt S's Avatar
Thanks Brian. Doug's comment sure made me look several times.
Richard,
Any help?
On the subscriptions, I saw 'No emails' and thought that's what I wanted. But the pulldown gives other options including 'Do not subscribe'.
I was able to delete all my subscriptions - had to try several times, kept getting errors, but it eventually worked.
Kurt S.
CRG -
Kurt S is offline
post #8 of 28 (permalink) Old Mar 9th, 16, 05:58 AM
Sorry I wasn't better help...I know I did it but only remembered where and forgot about the drop boxes
post #9 of 28 (permalink) Old Mar 9th, 16, 08:51 AM
69-Pace's Avatar
I'll see if Jeff saw this and has it on his list. I also noticed that the quotes are picking up quotes in non member areas - not good.
69-Pace is offline
post #10 of 28 (permalink) Old Mar 10th, 16, 07:43 AM
Administrator
John Doe
Where is it still picking up? We can turn that off no problem
Kyle
post #11 of 28 (permalink) Old Mar 12th, 16, 01:25 AM
Garth
I'm getting the quote notifications also using the Classic format. Would like to disable that feature if possible ? I don't even see how to delete each notification...
Garfields Maro is offline
post #12 of 28 (permalink) Old Mar 12th, 16, 01:26 AM
Garth
oops, double post. Delete please.
post #13 of 28 (permalink) Old Mar 25th, 16, 01:50 PM Thread Starter
Kurt S
Kurt S's Avatar
I too switched to the Classic format, but still get notified when some quotes me.
How do I disable this feature? Write less quotable information??
fwiw - I am subscribed to zero threads so it's not tied to that feature.
Kurt S.
CRG -
Kurt S is offline
post #14 of 28 (permalink) Old Mar 25th, 16, 04:06 PM
Tim
I got rid of the 'quote' alert by doing this:
Go to User CP.
On left hand menu, down near bottom click on 'Settings'.
Check the 'Quote Alerts' (described as 'Check this box if you want to hide the Quote alerts.')
I also checked the 'Mention Alerts' box too, fwiw.
Seems to have worked since doing that, i.e. no new forum messages.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is offline
post #15 of 28 (permalink) Old Mar 25th, 16, 10:45 PM
Garth
Thanks Tim !!!
