Search help - Team Camaro Tech
post #1 of 16 (permalink) Old Nov 12th, 17, 08:25 AM Thread Starter
Chris
Search help
I'm looking for help with using the search function here. I've used it a lot over the years with good success, but recently it doesn't seem to find anything or only a post or two. For example I'm looking for information on fan clutches. I've tried searching the forum in general and from more specifically launching the search from the engine forum, but with little success. If I use a search word like "fan" I get one hit. For a keyword that general, I'd think I'd get a hit on everything from radiator fans to heater fans, but instead I get virtually nothing. If I use "fan clutch" I get nothing. I've tried other search words too, but with zero hits. What's the trick? Why does the search function seem to work some times and other times not at all?
'69 Z/28, Lemans Blue/White Stripes, DZ302, Tremec Magnum, 4.10, Procar Elite Seats,
Custom Upholstery, Dynatech headers, 17" VWW V45's, 235/45, 275/40, C5 Front Brakes
ctcz28 is offline
post #2 of 16 (permalink) Old Nov 12th, 17, 08:42 AM
kevin
Re: Search help
ARE YOU USING THE SEARCH AT THE VERY TOP OF THE PAGE ShoppinImages
Videos
News
More
Settings
ToolsSafeSearch on
Explicit results filtered with SafeSearch. Learn more Undo
About 1,070 results (0.56 seconds)
Search Results
Clutch fan - Team Camaro Tech
https://www.camaros.net/forums/28-hea...lutch-fan.html
Feb 16, 2016 - 15 posts - 7 authors
I have a 1968 Camaro. It has a 383 with a long water pump. I was going to use a clutch fan. What clutch and fan blade would work best? I need ...
Fan Clutch for a 7-Blade Fan? - Team Camaro Tech
https://www.camaros.net/forums/28-hea...blade-fan.html
Jun 23, 2015 - 13 posts - 5 authors
I have been doing some reading on here on fan clutch's for this fan and it looks like some have used a standard duty clutch and some have ...
max RPM - clutch fan - Team Camaro Tech
Oct 3, 2006 - 6 posts - 5 authors
I thought the clutch part of a clutch fan setup operated based on temperature. But my replacement 7 blade has a sticker that says "max RPM ...
Clutch fan question. - Team Camaro Tech
https://www.camaros.net/forums/18-eng...-question.html
Sep 15, 2013 - 15 posts - 3 authors
Was thinking about replacing the flex fan on my Camaro with a good OEM style clutch fan. Have read where the flex fan can be costing ...
Flex fans suck! 7 blade fan is the way to go - Team Camaro Tech
https://www.camaros.net/forums/28-hea...-fan-way-go.ht...
Aug 18, 2006 - 15 posts - 9 authors
The radiator finally got the temp between 190-210 however when I changed back to an old 7 blade clutch fan, my temps went down the most ...
Radiator fan/clutch options - Team Camaro Tech
https://www.camaros.net/forums/28-hea...h-options.html
Mar 8, 2004 - 15 posts - 5 authors
It looks like I can get a Flex-a-lite clutch and Derale flex fan for under $100. Does this sound like money well spent? I am on a budget, but I don't ...
Recommendations on Fan/fan clutch - Team Camaro Tech
https://www.camaros.net/forums/28-hea...an-clutch.html
Apr 16, 2015 - 12 posts - 7 authors
I have a large shroud, which they said was good, but a fan clutch would be much more efficient than what I have. Can anyone suggest what I ...
Heavy Duty Fan Clutch vs Standard Fan Clutch - Team Camaro Tech
https://www.camaros.net/.../28.../205...an-clutch.html
Feb 23, 2012 - 11 posts - 3 authors
I only ask is because I ordered this: HAYDEN Part # 3568 Flex Fan For Standard Rotation Standard Duty Thermal Fan Clutch Flex.
5 blade clutch fan 67/68? - Team Camaro Tech
https://www.camaros.net/forums/15-tag...n-67-68-a.html
Jun 29, 2015 - 15 posts - 6 authors
Friend has fan that is 5 blade and checking if 3.25 diameter with 4 rivets. Is this the correct fan 67-68 z 28 and L78. Currently has 69 clutch on it.
Clearance between fan and radiator - Team Camaro Tech
https://www.camaros.net/forums/18-eng...-radiator.html
Apr 8, 2001 - 15 posts - 5 authors
When I went to mount the fan, there wasn't enough clearance between the ... Anyone out there have a stock BB radiator/clutch fan setup?
Ads
Fan Clutch
Adwww.rockauto.com/
Find cooling system parts at low prices in unique auto parts catalog
Serving Online Since 1999 ∑ Est. 1999
Highlights: Makes Affordable Auto Parts, Family Business Founded In 1999
How To Change A Fan Clutch - Find How To Change A Fan Clutch.
Adwww.informationvine.com/Answers
Types: Business, Health, Travel
Engine Fan Clutch - Find our Lowest Possible Price
Adwww.shop411.com/Engine+Fan+Clutch
Engine Fan Clutch for Sale
Narrow by Price ∑ Shop by Department ∑ Search Millions of Items ∑ Research. Shop. Save.
Types: Shopping, Research, Compare & Buy
flat tire is offline
post #3 of 16 (permalink) Old Nov 12th, 17, 08:58 AM Thread Starter
Chris
Re: Search help
I'm using the Classic View the forum offers. From that, I've tried using the Search that appears at the top of the page on the second red bar which I assume searches the entire forum for the keywords and I've tried going to the engine forum and using "search this forum" with the same results. I'm using an ipad instead of a PC, but I wouldn't think that would make a difference.
ctcz28 is offline
post #4 of 16 (permalink) Old Nov 12th, 17, 09:20 AM
kevin
Re: Search help
right under TEAM CAMARO there is a red bar. it starts with index and ends with search
I used THAT search function, typed in clutch fan and you can see the results in my first post. that is one of many pages
FWIW I also use the classic view
post #5 of 16 (permalink) Old Nov 12th, 17, 09:49 AM Thread Starter
Chris
Re: Search help
Interesting, I tried that one and specified search "our site" and got a whole bunch of hits; thanks. It seems odd that the search option that appears in the second red bar or the one invoked from within a particular forum, i.e., "search this forum" yield few if any results. I appreciate your help.
ctcz28 is offline
post #6 of 16 (permalink) Old Nov 13th, 17, 09:58 AM
Administrator
John Doe
Re: Search help
this one?
Which of the searches?
Lee
Administrator is offline
post #7 of 16 (permalink) Old Nov 13th, 17, 05:13 PM Thread Starter
Chris
Re: Search help
Yes, that one did not work nor does the one entitled. "Search this Forum" invoked from a specific forum, e.g. Search for "fan clutch" from the Engine forum yields zero results. Seems only the one at the very top of the Classic view with the drop down that says "our site" yields anything. I seem to remember being able to launch a search the the other locations on the site labeled "Search", but apparently no longer.
ctcz28 is offline
post #8 of 16 (permalink) Old Nov 14th, 17, 09:06 AM
Administrator
John Doe
Re: Search help
Do you get different results from using the full skin?
Also alternatively, does the Google search button give you the results you want?
Best regards,
Ed
post #9 of 16 (permalink) Old Nov 27th, 17, 09:15 PM
RSS
Rick
Re: Search help
I've been having the same exact problem as Chris. I just tried searching "fan clutch" like both Kevin and the administrator suggested with "no results". I also searched "master cylinder", "Camaro", "oil", "wheel" and other basic words and each time I get "no results found". In the past I usually searched in an individual forum like Chris explained and would get multiple pages of results. I have been using the search feature here for years flawlessly and have never experienced this. Has something changed with the forums that I am not aware of?
It takes a fool or an idiot to first criticize! It takes a wise and intelligent man to first ask why!
1969 coupe under going restification (Almost Done!)
RSS is offline
post #10 of 16 (permalink) Old Nov 27th, 17, 10:21 PM
Garth
Re: Search help
x3, something is wrong with the search function. I tried the same search I did successfully a week ago and got "sorry- no matches..." today. I usually go to whatever particular forum is most relevant and perform the search there.
Garfields Maro is offline
post #11 of 16 (permalink) Old Nov 28th, 17, 03:54 AM
kevin
Re: Search help
it is not working for me now
I tried to search FAN CLUTCH and it brought me back to this post
post #12 of 16 (permalink) Old Nov 28th, 17, 04:29 AM
Brett
Re: Search help
I try to use the one below in the pic, as it's really the only one I see, other than "Advanced Search". It returns almost nothing.. The one above it and to the right I've always thought was just an internet google search, and not within the forum.
Brett......
Rockets Up In 2020!
Brettallen59 is offline
post #13 of 16 (permalink) Old Nov 28th, 17, 09:06 AM
Administrator
John Doe
Re: Search help
Hi,
I've had success using the Google Custom Search in the top right. I am viewing the full camaros.net skin in Google Chrome.
Fergus
post #14 of 16 (permalink) Old Nov 28th, 17, 09:30 AM
Administrator
John Doe
Re: Search help
Recreated some examples of the search not working properly and I have enough to work with to bring this up with the tech team. Filing a ticket now.
Case #2829888
Kevin
post #15 of 16 (permalink) Old Nov 28th, 17, 05:55 PM
69-Pace's Avatar
Re: Search help
Kevin - The VB search has not worked for a long time, any skin. You will find an open ticket from April or May that I opened with Jeff. I just assumed it was fixed back them.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
