Adding a GIF. - Team Camaro Tech
 2Likes
  • 2 Post By DOUG G
post #1 of 12 (permalink) Old May 29th, 18, 06:42 PM Thread Starter
Gary
69Z28's Avatar
Adding a GIF.
Is adding a GIF treated the same as adding a pic in the Drag and Drop File Upload section? Seems I can do a pic but not a GIF. Any settings need to be changed/set, or is there a step I'm missing? Thanks.
06A 1969 Camaro Z28 711 69 B Black Stripes Console w/tach and gauges
69Z28 is offline
post #2 of 12 (permalink) Old May 31st, 18, 11:55 AM
Administrator
John Doe
Re: Adding a GIF.
Can you try adding the gif using the advanced editor and not drag and drop? It could be an issue with the filetype in general and I'd like to rule it out
Kyle
Administrator is offline
post #3 of 12 (permalink) Old May 31st, 18, 03:05 PM Thread Starter
Gary
69Z28's Avatar
Re: Adding a GIF.
I'll give it a shot.
69Z28 is offline
post #4 of 12 (permalink) Old May 31st, 18, 03:28 PM Thread Starter
Gary
69Z28's Avatar
Re: Adding a GIF.
Clicked on MANAGE ATTACHMENTS below and browsed to the file on my files. Uploaded a test file "GIF test" and only found a pic.
69Z28 is offline
post #5 of 12 (permalink) Old May 31st, 18, 03:39 PM
Re: Adding a GIF.
Put [img] in front of it and [/img] behind the properties.....no spaces.
Only certain files are supported.
like....
https://media.giphy.com/media/PmpA5ohOUl1xC/giphy.gif
and add the above (front)----> [img] (tail end)-----> [/img] on each end with NO spaces......
68 Camaro~LSx ~all motor
post #6 of 12 (permalink) Old May 31st, 18, 04:45 PM Thread Starter
Gary
69Z28's Avatar
Re: Adding a GIF.
like....
My first shot at loading a gif. I'll get it eventually.
69Z28 is offline
post #7 of 12 (permalink) Old May 31st, 18, 05:24 PM
Re: Adding a GIF.
I know you will......persistence
69Z28 and Administrator like this.
post #8 of 12 (permalink) Old Jun 4th, 18, 08:47 PM Thread Starter
Gary
69Z28's Avatar
Re: Adding a GIF.
OK Doug...you can officially call me a DUMMY. I still can't figure it out. I have a great GIF I want to attach to certain post, (wink, wink). It's loaded on my computer, but lost on how to get it from there to here. You mentioned properties, I get what needs to happen, but don't see properties to add the IMG string.
69Z28 is offline
post #9 of 12 (permalink) Old Jun 5th, 18, 06:46 PM
Re: Adding a GIF.
Is it or can it be hosted on-line ?
Yes ?
Right click on the gif, on line, copy the properties.
Link it here with the img tags.
__________________________________________________ _______________-
OK, did a quick test.
IF its on your computer, you can click on the GO ADVANCED tab below post box.
Use the paperclip to add attachment.
It wont act as a .gif until it's clicked on or someone puts their pointer on the pic/gif to open it in another page.
post #10 of 12 (permalink) Old Jun 5th, 18, 08:13 PM Thread Starter
Gary
69Z28's Avatar
Re: Adding a GIF.
Yes ?
Use the paperclip to add attachment. It wont act as a .gif until it's clicked on or someone puts their pointer on the pic/gif to open it in another page.
Found the GIF online...no properties indicated. I did upload to my computer.
Did your bottom suggestion first go around and came up with just the .jpg, and the last one shown is the same.
Had to go to CLASSIC to find GO ADVANCE...but even in that mode I was still getting the same deal, a .jpg when I clicked on MANAGE ATTACHMENTS in FULL version. Actually FULL version gets you to the browse attachment minus a step.
This is SUPPOSED to be fairly easy, your explanation is correct, but damn if I can get it. Pretty damn sure I had done this on another site years ago and it worked.
69Z28 is offline
post #11 of 12 (permalink) Old Jun 6th, 18, 03:41 AM
Re: Adding a GIF.
Can you PM me the link ?
post #12 of 12 (permalink) Old Jun 6th, 18, 12:16 PM Thread Starter
Gary
69Z28's Avatar
Re: Adding a GIF.
OK Doug. You should have it.
69Z28 is offline
