pics not showing - Team Camaro Tech
post #1 of 13 (permalink) Old Aug 19th, 18, 03:22 PM Thread Starter
1Slow64
pics not showing
Pics from other posters and my posts aren't showing. Any ideas?
My 69 X66 project.
69X66 is offline
post #2 of 13 (permalink) Old Aug 20th, 18, 05:43 AM
69-Pace's Avatar
Re: pics not showing
Intermittent issues since the move to the cloud.
Uploading new pictures takes much longer to complete even after the screen says they have it takes a couple minutes before the thumbnails appear.
And in some older threads, you see the attached thumbnails text but no thumbnails, come back a few minutes later there they are.
It's been reported but no definitive answer.
Tell us the thread(s) and the OS and browser you are using.
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #3 of 13 (permalink) Old Aug 20th, 18, 04:47 PM
I've had the same issue today on 2 different computers. Also the drop down menus aren't dropping down the options. Windows 8.1 IE11 for both computers.
Here's one thread for example.
https://www.camaros.net/forums/27-tr...-bearings.html
my 67' build thread:
allanjs is offline
post #4 of 13 (permalink) Old Aug 20th, 18, 05:17 PM
Looks like it might be an IE thing. Everything is working using Chrome.
allanjs is offline
post #5 of 13 (permalink) Old Aug 20th, 18, 07:02 PM
69-Pace's Avatar
Exclamation Re: pics not showing
Recent security changes here going to secure HTTPS in IE may have turned on the mixed content warning. It is either set to denied, prompt or allow. You should add the site to trusted list and then switch mixed content to allow for the trusted list.
See this thread for details https://www.camaros.net/forums/20-ca...humbnails.html
69-Pace is offline
post #6 of 13 (permalink) Old Aug 20th, 18, 07:27 PM
I had already done that Brian. Didn't fix it but I will double check I have the setting correct.
allanjs is offline
post #7 of 13 (permalink) Old Aug 21st, 18, 05:53 AM
69-Pace's Avatar
Okay let us know
69-Pace is offline
post #8 of 13 (permalink) Old Aug 21st, 18, 07:21 AM
Administrator
John Doe
Testing Image Upload.
For those of you using IE you may want to check your settings to help with this issue. (It may be under the "gear".)
Tools>Internet Options>Security tab>Custom Level button>Display Mixed Content>Enable (see if it is set to "Prompt" and uncheck that if it is)
- Cricket
Administrator is offline
post #9 of 13 (permalink) Old Aug 21st, 18, 07:29 AM
Brian, I went through all of the steps outlined in your linked thread.
It made no difference. I also have to load the site 2 times. 1st time
I just get a white page with the site address showing in the browser.
All works as normal in Chrome so apparently there is a conflict with IE 11.
Too anyone following the reset internet options steps be aware you will
loose any and all changes you have made previously and Brian mentions
that in his directions. You're most likely going to say where the h**l did that go ? etc.
At least I did and trying to recall how to reset those settings was a challenge.
allanjs is offline
post #10 of 13 (permalink) Old Aug 21st, 18, 07:41 AM
- Cricket
I have tried all 3 available settings (enable disable prompt) and always get the "Only secured content is displayed" message.
If I click on "show all content" the pics then show and the drop downs work. Problem is I have to do that with every page and thread.
For some reason the Display Mixed Content setting isn't taking effect.
allanjs is offline
post #11 of 13 (permalink) Old Aug 21st, 18, 11:16 AM
Apparently this problem was caused by a Windows auto update installed on 8-14. I restored my computer to a point previous to the update and all is well now. One good reason to create a restore point regularly.
allanjs is offline
post #12 of 13 (permalink) Old Aug 22nd, 18, 07:07 AM
Just an update. Windows did an auto update when shutting down yesterday. This time no ill effects so I'm assuming whatever the problem was with the previous update has been fixed.
allanjs is offline
post #13 of 13 (permalink) Old Aug 22nd, 18, 10:43 AM
Administrator
John Doe
Well good to hear it. Keep us posted if it gives you trouble again
Kevin
