Bleeding Brakes - Page 3 - Team Camaro Tech
 2Likes
post #31 of 42 (permalink) Old Feb 13th, 20, 09:40 PM
Change all the rubber hoses if not changes in the last 10 years. I bet the rear is plugged tight
1968 that started life and a 6 banger with a PG. Now it's a 350 with a TKO600, Moser 12 bolt, Speedtech LCA/UCA, ATS Tall Spindles, Hotchkis Springs, Forgeline ZX3P, C5 (Kore3) brakes with other cool stuff from Ron Davis, Vintage Air and soon to be Terminator EFI.
eville is online now
post #32 of 42 (permalink) Old Feb 14th, 20, 06:19 PM
Joe
Re: Bleeding Brakes
Itís a matter of getting dirty and troubleshooting where you are and are not getting fluid. Or you can just throw parts at it until you get lucky.
67 RS/SS 350 4sp.
Silvrmax04 is offline
post #33 of 42 (permalink) Old Feb 14th, 20, 07:15 PM
Probationer
Re: Bleeding Brakes
close rear bleeders and open front bleeders and push the pedal. That should work.
or
take off rear line at the proportioning valve. use something small and blunt and put it in the proportioning valve pushing the plunger back a little. Some fluid will come out. put rear line back on. Then gravity bleed both rears. Then after a while, bleed like normal.
captblue1 is offline
post #34 of 42 (permalink) Old Feb 15th, 20, 11:34 AM Thread Starter
Apprentice
Re: Bleeding Brakes
I got fluid down the proportioning valve under the drivers seat, having a difficult time getting the fittings off to check flow.
Jworon is offline
post #35 of 42 (permalink) Old Feb 15th, 20, 11:44 AM Thread Starter
Apprentice
Re: Bleeding Brakes
The device is called a brake hold off valve mounted on the frame rail under the drivers seat. Does this device have any internal part that could fail and not allow fluid through it? Also I have no rubber hoses on my rear brakes, they are metal right into the drums.
Jworon is offline
post #36 of 42 (permalink) Old Feb 15th, 20, 11:55 AM
Re: Bleeding Brakes
Are you saying you cracked the line open on the front of the valve and got fluid and can not break it free to check if its coming out the rear of the valve? I don't know about the valve failing and what it may cause. There is a rubber hose for the back brakes. Basically just follow the metal line from the valve to the rear end. You will see it attaches to a splitter and from there the metal lines go to each rear wheel cylinder. You should be able to crack the line open at the splitter and check for fluid.
yellow69RS likes this.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #37 of 42 (permalink) Old Feb 15th, 20, 12:17 PM Thread Starter
Apprentice
Re: Bleeding Brakes
I have fluid at the rear brake connection on the manifold under the MC, that line runs to the pressure regulator valve which is on the frame rail under the drivers seat. I canít break the connections to this device, I donít want to strip the nuts. Iím guessing this is the device not letting fluid by.
Jworon is offline
post #38 of 42 (permalink) Old Feb 15th, 20, 01:31 PM
Jeff
yellow69RS's Avatar
Re: Bleeding Brakes
Go to the rear differential near the center. There is a rubber hose there with three places to crack the fittings and check for fluid pressure. If you can't crack the line into the rubber crack one of the two out of it. If no fluid comes out do what you have to do to either crack the fitting into the rubber or the end coming out of the valve under the drivers seat. You will have to repair the collateral damage no matter what the outcome.
Jeff
yellow69RS is offline
post #39 of 42 (permalink) Old Feb 15th, 20, 01:47 PM
Make sure you’re using line wrenches.
post #40 of 42 (permalink) Old Feb 15th, 20, 02:27 PM Thread Starter
Apprentice
Re: Bleeding Brakes
I am using line wrenches,
They are just tough to get loose
Jworon is offline
post #41 of 42 (permalink) Old Feb 15th, 20, 03:03 PM
Joe
Re: Bleeding Brakes
If you are getting fluid to the valve under seat and can not open the lines in the 3 way over diff or at either of the rear cylinders then you need to replace everything from the valve back.
67 RS/SS 350 4sp.
post #42 of 42 (permalink) Old Feb 15th, 20, 04:53 PM Thread Starter
Apprentice
Re: Bleeding Brakes
No I have fluid from the distribution block to the rear brakes, the valve under the seat I cannot get the fittings out
Jworon is offline
