69 Big block carbon fouling - Team Camaro Tech
Test Drive! New to this area?
Get comfortable here by posting and editing your own messages.
post #1 of 8 (permalink) Old Apr 17th, 07, 08:43 AM Thread Starter
I have an original 396 camaro with stock exhaust manifolds 2.5 in exhaust dual plane alluninum intake 780 holley I have tried new carbs and it keeps carbon fouling plugs Would hotter plugs help ? Maybe a spacer under the carb? The car is a factory 4 speed and i'm currentlly running a 308 rear gear for milage for the power tour. Any help would be great.
Little69
jr little is offline
post #2 of 8 (permalink) Old Apr 17th, 07, 03:40 PM
Re: 69 Big block carbon fouling
if carbon keeps fouling plugs than you need to get in it big time.put it in first go floor it to around 4500 rpms like you racing it need to blow it out. sounds like you drive like an old lady lol. also throw some tranny fluid down carb few teaspoons will smoke but it will loosten carbon up.than go drive.
jaguareats is offline
post #3 of 8 (permalink) Old Apr 17th, 07, 05:27 PM
Welcome Back - Senior Tech
Where are you in Ohio Junior? I'm in the Lima area. Welcome to TC and here is a free bump! I would ditto what jaguar said and if that doesn't work then you may have a problem.
the learning curve is....expensive
1969 Camaro
bearcat44 is offline
post #4 of 8 (permalink) Old Apr 18th, 07, 05:14 AM Thread Starter
Thanks for the help , I've driven to Texas and Florida and it runs good no fouling then, just in town driving maybe I do baby it to much . I live outside Dayton I 'll try anything .
JR
post #5 of 8 (permalink) Old Apr 18th, 07, 08:30 AM
Well, carbon fouling can be weak ignition, rich fuel mixture, or too cold on the plugs.
What ignition are you running? What heat range plug are you running?
If it doesn't foul at highway speed, I'd lean (pun intended) to it needing some carb adjustment; it sounds too rich in the idle circuit.
https://www.camaros.net/techref/articles/holley_1.htm
Eric
Eric Kammerer is offline
post #6 of 8 (permalink) Old Apr 18th, 07, 10:09 AM
I'd go for a hotter plug, advance timing a hair, and stay one gear short of normal.
I'd also run a can of BG 44K in the fuel tank.
post #7 of 8 (permalink) Old Apr 19th, 07, 05:39 AM Thread Starter
Exclamation Re: 69 Big block carbon fouling
The ignition is a petronix with high volt coil also from petronix plugs are AC r44 I think xls and accel wires . I'm also thinking of changing the rear gears to 3.55 s . What do you think ?
post #8 of 8 (permalink) Old Apr 19th, 07, 06:16 AM
I'd go to, at least, an AC 45 plug. The higher the AC number, the hotter the plug.
Big Block vs Small Block P.S. pump RaisinCayne Brakes, Suspension & Steering 5 Nov 27th, 06 05:19 AM
Big Block Heater Core vs Small Block Heater Core South Side Goons & Hitmen Heating & Cooling 1 Nov 12th, 06 12:12 PM
69 Big block shifter rods TOM BARKLEY Transmission & Driveline 0 Jun 2nd, 06 10:24 PM
69 big block convt on ebay?? TENZS Bench Racing 3 May 18th, 06 05:27 AM
Carb Dates DZ Fool Tag Team 16 Apr 2nd, 06 11:44 AM
