Dash and running lights not working - Team Camaro Tech
Test Drive! New to this area?
Get comfortable here by posting and editing your own messages.
post #1 of 4 (permalink) Old May 17th, 10, 10:52 AM Thread Starter
Jerry
I have a 69 standard coupe with a V8350 automatic. It is in running condition till I start resto. Recently the dash lights and running lights quit working. I replaced the light switch, nothing. I remove the connector to the switch and using a jumper wire I can get all the lights to work. All fuses are good. What am I missing to get these lights working?
69newbie is offline
post #2 of 4 (permalink) Old May 17th, 10, 10:57 AM
Re: Dash and running lights not working
Another headlamp switch providing all external of the switch is the same.
post #3 of 4 (permalink) Old May 17th, 10, 11:20 AM Thread Starter
Jerry
Not sure what you mean?
69newbie is offline
post #4 of 4 (permalink) Old May 17th, 10, 11:31 AM
Another member here, I believe had the same problem and it turned out to be the repo headlamp switch.
If nothing else other than the switch has been changed since last time the lights worked, then its the switch. From your first post, you jumpered across the connector to get the lights of choice to work, and they did. If the harness connector to the switch has not been changed from as manufactured, then its the replacement switch.
