my camaro - Team Camaro Tech
Test Drive! New to this area?
Get comfortable here by posting and editing your own messages.
post #1 of 6 (permalink) Old Jun 30th, 11, 09:52 AM Thread Starter
Apprentice
danny
my camaro
hi,
I have a 68 camaro with a inline six and I really what to put a 350 v8 in it but i have no clue what to do, can somebody help me?
camarolover#1 is offline
post #2 of 6 (permalink) Old Jun 30th, 11, 09:57 AM
Russ
Re: my camaro
Luckily it's not very hard to swap motors in a 1st gen Camaro. You will need the motor complete with any accessories, motor mounts, and more than likely a radiator. I'll assume you have either a 2spd Powerglide auto or a 3spd manual trans. Either could be used or you could upgrade to a 3spd auto or 4,5,or 6spd manual trans. A trans change would require a new driveshaft or having yours modified.
Being in Highpoint you are fairly close to some of the best made aftermarket parts for Camaros by DSE.
Russ (RJ)
The Garlic Capital, Gilroy,CA
(sold June 15,2014) 1968 RS convertible that is not quite stock
rj68RS is offline
post #3 of 6 (permalink) Old Jun 30th, 11, 10:08 AM Thread Starter
Apprentice
danny
Re: my camaro
Could i keep the same trans?
post #4 of 6 (permalink) Old Jun 30th, 11, 10:40 AM
Camarodude67
Re: my camaro
Yes you can use the same transmission, crossmember and driveshaft.
Jeff G.
camarodude67 is offline
post #5 of 6 (permalink) Old Jun 30th, 11, 12:04 PM
Re: my camaro
Danny -
It would help a little to know which trans you have. The L6 Glide has different ratios and is generally believed to be weaker. If you have the base 3-speed manual, it also has different ratios, but I don't think strength is as much of an issue.
Just understand that is is a "snowball" project; you can make some things work with rigged up kind of fixes, but it will take more money and time to do it right. If you really want to do it, you'd better do a lot of research or have deep pockets to pay someone to do it; if you "don't have a clue" and you want to jump right in without thinking things through, you're just creating the next "I started an engine swap, but I couldn't finish, so I am selling it cheap..."
If the car is an original L6 car, it likely has monoleaf rear springs and a non-posi, low numerical ratio rear axle. None of these are desirable behind a strong V8, but might live for a while depending on how it is driven.
A small block V8 car uses different engine frame stands (bolts to subframe) and engine mounts (bolts to block) than an L6 car; these are available used OE or repro. You may want to read up on the different types of mounts used in the different cars http://pozziracing.com/camaro_engine.htm . If you intend to run a later model 350 with a large (8-inch) balancer, you need to use a certain combo.
You will need a shroud and likely a new radiator. You can probably try rigging the engine and front lighting wire harnesses to work (my L6 69 vert had been rigged to run a small block, but the wiring looked awful), but it is better to replace them with the correct small V8 style.
There are many threads here on this forum regarding this exact question, because it is a commonly asked question. Try typing "small swap" and see if a bunch of relevant threads don't come up.
Eric
Eric Kammerer is offline
post #6 of 6 (permalink) Old Jun 30th, 11, 12:11 PM Thread Starter
Apprentice
danny
Re: my camaro
Thanks you save me a lot of time, and defenitly look into that.
