Help adjusting door glass !!!!! - Team Camaro Tech
 1Likes
post #1 of 21 (permalink) Old Jun 12th, 18, 05:00 PM Thread Starter
Brad
Hi I have a 1969 camaro which both of my doors don’t shut very good. The problem is the window glass is tipped in to far and hitting the weather strip and is too tight. The glass needs to be tipped out. They go up and down nice and even they are just tipped in too much. Can someone help me on how to adjust them I have never messed with this. Please help!! Thanks Brad
69crush is offline
post #2 of 21 (permalink) Old Jun 12th, 18, 05:33 PM
keith
X-77 keith's Avatar
You have to take the door panel off. There are adjustments in the front top and rear top. It sounds crazy, but move it the opposite way you think it will need to go. I know it sounds dumb, but that's the best advice I can give you.
X-77 keith
X-77 keith is offline
post #3 of 21 (permalink) Old Jun 12th, 18, 05:40 PM
Daryl
1968RallySport's Avatar
Re: Help adjusting door glass !!!!!
1968 Rally Sport
302ci
Muncie M22
Moser 12-bolt 4:10 posi
1968RallySport is offline
post #4 of 21 (permalink) Old Jun 12th, 18, 05:54 PM Thread Starter
Brad
Ya I watched that but not very specific.
69crush is offline
post #5 of 21 (permalink) Old Jun 12th, 18, 05:56 PM
keith
X-77 keith's Avatar
Nothing really good on you tube on it. Took forever to do mine . trial and error.
X-77 keith
post #6 of 21 (permalink) Old Jun 12th, 18, 06:06 PM
Daryl
Open this pdf. It looks fairly good.
http://www.pro-touring.com/attachmen...6&d=1426938898
Some more information:
https://www.camaros.net/forums/1743421-post6.html
1968 Rally Sport
302ci
Muncie M22
post #7 of 21 (permalink) Old Jun 13th, 18, 03:32 AM
Greg
pittpens24's Avatar
Is it original glass or aftermarket? I had major issues with my aftermarket glass from Metro Glass - the glass itself had too much curve to it causing some major modification to get it to work and still closes a bit tight.
Hours of trial and error unless you just get super lucky.
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #8 of 21 (permalink) Old Jun 13th, 18, 07:15 AM Thread Starter
Brad
It’s aftermarket ☹️
69crush is offline
post #9 of 21 (permalink) Old Jun 14th, 18, 09:41 AM
Robert
What I did. Loosen all the adjustment bolts. Use one (or 2) of those glass suction cups on the outside. adjust the glass to where you want it with the door closed and have someone inside tighten all the bolts. Didn't come out showroom perfect but Im happy with the results.
69-Pace likes this.
Vegas69RS is offline
post #10 of 21 (permalink) Old Jun 16th, 18, 07:48 AM Thread Starter
Brad
It ended up being my door striker . But if I adjust it so my door shuts real nice the door sticks out to much ??? So how do I fix that ??
69crush is offline
post #11 of 21 (permalink) Old Jun 16th, 18, 10:35 AM
Robert
with the window down the door striker needs to be adjusted first to get the gap you want. If the window doesn't align correctly after that then its glass adjustment.
post #12 of 21 (permalink) Old Jun 16th, 18, 10:57 AM Thread Starter
Brad
It shuts the same window up or down
69crush is offline
post #13 of 21 (permalink) Old Jun 16th, 18, 08:02 PM
Garth
Sounds like the door weatherstrip is too stiff (firm). What brand do you have ? Most folks, including myself, prefer Metro.
If they're relatively new, give it a few weeks for the W/S to conform.
Garfields Maro is online now
post #14 of 21 (permalink) Old Jun 17th, 18, 12:07 PM Thread Starter
Brad
Ya I have been thinking about getting metro
69crush is offline
post #15 of 21 (permalink) Old Jun 20th, 18, 04:53 AM
Jon
youtube scared shiftless. he just did a series of videos on rebuilding and adjusting both door and quarter glass within the last month. its like a 7 part series and it helped me out a bunch.
I had the front 2 window guide tracks swapped side to side and fought it for a day before I figured it out! doh! mine too seem tipped in to far, stock glass, but I think its the weather stripping that is just
very full and new. roll up and down nice.
I need to let it sit out in the sun windows up for a day to relax the rubber. helped out my trunk seal doing that this week.
hope that helps
saon is offline
