Courtesy Lights - Team Camaro Tech
post #1 of 10 (permalink) Old Nov 1st, 18, 05:19 PM Thread Starter
Courtesy Lights
Ok, small victory. Got some 67 bulbs (Don, wanted a skoosh more light), still waiting on console festoon light (212 LED warm). Question, I remember reading about the courtesy lights having three switches. Door - Door - Light switch. Well each door turn on lights, cool. How does light switch work? I remember from 100 years ago to turn the headlight knob, but that didn't work. Turned ignition on (not started) and tried again and nothing.
Am I doing something wrong, bad light switch, or just an EXTREME NOOB? Not overly concerned and my main concern was operation on doors and that is good. Mainly curious to the 3rd switch.
Can't believe how happy I am to have light, little things in life.
1967 RS/SS Vert (non matching)
aggiegoalie is offline
post #2 of 10 (permalink) Old Nov 1st, 18, 06:05 PM
Re: Courtesy Lights
You should be able to twist the headlight knob counterclockwise and then feel some resistance but then with a little more twist, you should feel a click with some slight amount of resistance and then a little more counterclockwise rotation. This should turn on the courtesy lights as long as they were off before (door closed). If for some reason the headlight switch does not rotate counterclockwise, see if it turns the other way (it may already be at the full counterclockwise position). It should not take a lot of pressure to rotate and click on the dome light switch on so no need to get out the pliers to twist it
The headlight switch connects a ground to turn on the courtesy lights and does not require the ignition switch to be turned on.
SOA-Nova is offline
post #3 of 10 (permalink) Old Nov 1st, 18, 06:20 PM Thread Starter
Re: Courtesy Lights
Noob, for sure. Thanks Jim, that is what it took.
Think my dad's Caddy had a dimmer that is why I was going clockwise, as it felt like it was a dimmer switch.
post #4 of 10 (permalink) Old Nov 1st, 18, 06:38 PM
Roger
rogerh's Avatar
Re: Courtesy Lights
This is the page in the manual that explains headlight switch operation.
Roger
rogerh is offline
post #5 of 10 (permalink) Old Nov 1st, 18, 07:20 PM Thread Starter
Re: Courtesy Lights
Roger
Thanks Roger,
Looks like what I thought was dimming was for instrument lights. Didn't pay attention on that.
Just check, instrument lights don't seem to change while rotating clockwise, come on but no change in brightness. But the counter-clockwise click does turn on courtesy lights, so I think I am good
post #6 of 10 (permalink) Old Nov 2nd, 18, 10:39 AM
Re: Courtesy Lights
If we knew everything from day one, we would be VERY dangerous
We all have to learn and we have all been noob's at some point.
I'm going to be a noob if I ever install a twilight sentinel in one of my cars.
SOA-Nova is offline
post #7 of 10 (permalink) Old Nov 2nd, 18, 01:54 PM
Lee
Re: Courtesy Lights
Thanks Roger,
The dimming function won't work if you replaced the dash bulbs with LED bulbs. The LED bulbs require much more resistance (like hundreds of ohms) before they will start to dim and the rehostat in the light switch is only like 4 or 5 ohms.
blitzer454 is online now
post #8 of 10 (permalink) Old Nov 2nd, 18, 01:58 PM Thread Starter
Re: Courtesy Lights
I didn't change the dash bulbs.
The under dash bulbs are incandescent 67 bulbs. The light in console for rear seat is what I changed to a 212 LED (warm). My neighbor, '67 Bird, said his console bulbs got real hot, so I switched that one to LED. Upon his recommendation I went warm light, he thought the warm glow was more in line with tradition vs the BRIGHT WHITE from normal LED's. Good enough logic for me.
post #9 of 10 (permalink) Old Nov 2nd, 18, 02:10 PM
Lee
Re: Courtesy Lights
I learned something new, I didn't even know there was an under dash bulb, either mine never had one or someone else ripped it out before I got it.
Ah, who doesn't like warm light it's so warm. I switched out my dome light for LED bulb, it was much brighter and doesn't melt the cover like the original bulb did.
post #10 of 10 (permalink) Old Nov 2nd, 18, 03:38 PM Thread Starter
Re: Courtesy Lights
Think neighbor was right, I like the warm light in classic car:
