'67 Camaro Seat Backs - Team Camaro Tech
post #1 of 12 (permalink) Old Nov 4th, 18, 06:34 AM Thread Starter
Andrew
Andrew69's Avatar
I believe it is correct the '67 Camaro has metal seat backs with paint. Are they the same color as the car's body or painted black? Either way are they a gloss finish or a semi-gloss?
Thank you,
Andrew
Skunk Works
Some photos:
Member # 159
Andrew69 is online now
post #2 of 12 (permalink) Old Nov 4th, 18, 06:40 AM
Re: '67 Camaro Seat Backs
Yes, metal backs painted interior color and painted same gloss as rest of metal interior parts.
post #3 of 12 (permalink) Old Nov 4th, 18, 01:13 PM
Michael
67 used a semi-gloss interior paint. I believe it was toned down in 68 and 69.
Agreed, the metal seat backs were the same gloss, though the texture doesn't allow it to look as glossy.
67 LOS SS/RS L35 Hardtop - Original w/UOIT
67 NOR SS/RS L35 Convertible - Restored
Mike_S is offline
post #4 of 12 (permalink) Old Nov 15th, 18, 09:11 AM Thread Starter
Andrew
Andrew69's Avatar
What color is correct for the bar across the top of the rear fold down seat? Interior color or this silver color or something else?
Skunk Works
Some photos:
Member # 159
post #5 of 12 (permalink) Old Nov 16th, 18, 10:29 AM
Russ
Metal seat backs changed to plastic in April-May 1967. More info here:
CRG Active Research Topics
Petes L48 is offline
post #6 of 12 (permalink) Old Nov 16th, 18, 12:04 PM Thread Starter
Andrew
Andrew69's Avatar
This is a Sept '66 built car so metal is correct. Just want to confirm the correct coloring.
Skunk Works
Some photos:
Member # 159
post #7 of 12 (permalink) Old Nov 16th, 18, 12:25 PM
Russ
Yep, correct for your car. Just wanted to add that 2 cents in, in case a future search is run by someone with a late 67.
post #8 of 12 (permalink) Old Jan 7th, 19, 08:06 AM Thread Starter
Andrew
Andrew69's Avatar
Is there a known paint color code for this interior blue color?
Skunk Works
Some photos:
Member # 159
post #9 of 12 (permalink) Old Jan 7th, 19, 10:38 AM
Andrew, The cowl tag will have the interior color code. You'll have to give
that code to your paint supplier and they will take it from there. My supplier
called the color library to get the formula.
Edit: This might help.
https://www.uniquecarsandparts.com.a...chevrolet_1967
my 67' build thread:
allanjs is online now
post #10 of 12 (permalink) Old Jan 7th, 19, 11:35 AM
Russ
I just posted this today, under a separate thread in the Interiors section. See post #3:
https://www.camaros.net/forums/23-in...ole-color.html
post #11 of 12 (permalink) Old Jan 8th, 19, 02:20 PM
Craig
Not to change subject. I have a Camaro built about sametime as yours in LA. Does your subframe have large holes in the front frame horns just below battery as most late build cars have or are there no large holes in the subframe. Mine does not have any approximately 4 inch holes in the inside of front subframe. I recently saw a car in CA that only had one hole. Just curious based on your build date and not knowing if your car was built in LA or in the east.
Agitator is offline
post #12 of 12 (permalink) Old Jan 8th, 19, 06:11 PM Thread Starter
Andrew
Andrew69's Avatar
Thank you
Thank you
Skunk Works
Some photos:
Member # 159
