dashpad - Team Camaro Tech
 2Likes
  • 1 Post By KevinW
  • 1 Post By 69ss350
post #1 of 11 (permalink) Old Nov 23rd, 18, 01:00 PM Thread Starter
Steven
stamatisg1977's Avatar
dashpad
hey guys few questions regarding the dashpad for a 69
1. is there a way to tell if it is an original
2. is there someone who does pad restoration if pad turns out to be original
3. if not original, what is the best fitting repo?
thank you all
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #2 of 11 (permalink) Old Nov 23rd, 18, 03:48 PM
Paul
Re: dashpad
http://www.justdashes.com/2015/08/ha...aArOxEALw_wcBQ
Not cheap but great quality.
Paul
fsc66 is offline
post #3 of 11 (permalink) Old Nov 24th, 18, 04:19 AM
Kevin
KevinW's Avatar
Re: dashpad
FYI, Just Dashes, does not fix 69 dash pads. Original ones have a yellowed plastic/resin core and urethane is molded on top. The resin core cracks and breaks. Most repros have a metal core and the better ones are pretty good.
dhutton likes this.
Kevin
KevinW is online now
post #4 of 11 (permalink) Old Nov 24th, 18, 05:17 AM Thread Starter
Steven
Yea i was wondering why i didnt see anything for a 69
Im gonna double check the backside of mine for the yellow resin
Tremec TKO 600
post #5 of 11 (permalink) Old Nov 24th, 18, 01:31 PM Thread Starter
Steven
Re: dashpad
mine is a repro, wasnt surprised but some of he mounting points are torn and its real dirty from sitting.
what company makes the best repro?
Tremec TKO 600
post #6 of 11 (permalink) Old Nov 24th, 18, 02:33 PM
Kevin
KevinW's Avatar
Re: dashpad
I got OER a while ago, fit pretty well, not sure who is the best now. The clips do not stay in so you have to do something to secure them. And I put a strip of velcro over the center of the dash (above clock location). Repros have this angle to them and they don't sit level, the velcro helps that.
Only crappy pic I could find, sorry
Kevin
post #7 of 11 (permalink) Old Nov 24th, 18, 03:26 PM Thread Starter
Steven
Nice Kevin.
Mine has that same problem over the clock. Good idea with the velcro
Tremec TKO 600
post #8 of 11 (permalink) Old Nov 24th, 18, 03:54 PM
Re: dashpad
I glue the clips in with panel adhesive. Works well.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #9 of 11 (permalink) Old Nov 24th, 18, 05:04 PM
keith
X-77 keith's Avatar
[QUOTE=KevinW;1783102645]I got OER a while ago, fit pretty well, not sure who is the best now. The clips do not stay in so you have to do something to secure them. And I put a strip of velcro over the center of the dash (above clock location). Repros have this angle to them and they don't sit level, the velcro helps that.
I had the same issues with my OER dash. I used windshield ribbon strip the even out the say over the clock. The clips did not fit well on mine either. I bent them just a hair and they worked. The glue is probably a better fix.
X-77 keith
X-77 keith is offline
post #10 of 11 (permalink) Old Nov 24th, 18, 05:50 PM
Misha
Re: dashpad
Classic Headquarters has the best OEM quality dash pad.
I have one and the fit is absolutely awesome. Its so close to the original pad, its amazing.
P/N: W-030 @ $370 each.
Worth every penny.
Classic Headquarters - Quality Restoration Parts for Classic GM Cars and Trucks
dhutton likes this.
69 Camaro Z27
69ss350 is offline
post #11 of 11 (permalink) Old Nov 24th, 18, 06:24 PM Thread Starter
Steven
Yes the pad i have now has the clips bonded with panel adhesive
Tremec TKO 600
