Removing Glue in Floor Pan - Team Camaro Tech
 1Likes
post #1 of 16 (permalink) Old Dec 17th, 18, 01:26 PM Thread Starter
Andrew
Andrew69's Avatar
I have removed, with great effort, the carpet from this '67 Camaro. Whoever installed the carpet had it glued down and it took a lot of tugging to remove. Before installing new carpet I want to put down sound deadening but I know it won't stick because of the glue residue.
I tried Acetone and PrepSol and neither would budge it. Does anyone have ideas?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #2 of 16 (permalink) Old Dec 17th, 18, 04:20 PM
Garth
Re: Removing Glue in Floor Pan
If lacquer thinner won't move it I'm not sure what will. Aircraft stripper will take it down to bare metal.
Why do you think the sound control mat won't stick?
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Ts
1977 Power Wagon
1978 Lil Red Express
69L48Z27 is offline
post #3 of 16 (permalink) Old Dec 17th, 18, 04:27 PM
Bobby
3M general purpose adhesive remover (or the specialty adhesive remover). spray or lightly pour it on the residue, give it a chance to weaken the adhesive and scrape away with a sharp plastic razor blade.
It takes some patience.
67 Camaro 350
M20 4spd console,
8.5, 30 spline Eaton posi 373
Cowl Plenum
Custom 180 Headers
black/black
no radio
Luwi67 is offline
post #4 of 16 (permalink) Old Dec 17th, 18, 04:54 PM Thread Starter
Andrew
Andrew69's Avatar
It left fuzzy residue in many places and the glue is rubbery and can be removed with great effort. I would prefer not to use stripper but we'll see.
Sounds interesting, I'll check that out.
Thank you
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #5 of 16 (permalink) Old Dec 17th, 18, 05:14 PM
Joe
Wire wheel.
67 RS/SS 350 4sp.
Silvrmax04 is offline
post #6 of 16 (permalink) Old Dec 17th, 18, 05:29 PM
Vega$69's Avatar
Elbow grease is the only thing I know will work
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 16 (permalink) Old Dec 17th, 18, 05:36 PM
I have had good luck with SPI solvent based wax and grease remover. Not the water based one.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #8 of 16 (permalink) Old Dec 17th, 18, 06:06 PM
I have never glued carpets. No need when installed properly.
HawkX66 likes this.
Call for restoration and custom paint scheduling:
Sauron67MM is online now
post #9 of 16 (permalink) Old Dec 18th, 18, 06:07 AM
Bill
i have same issue and looked around and found that when removing from house floors they use steam to soften the glue and then scrape it up
my previous owner glued carpet to THE WHOLE INTERIOR in the process of removal
bills69 is offline
post #10 of 16 (permalink) Old Dec 18th, 18, 07:56 AM
Patrick
The glue looks yellow. It could be 3M 08090 Super Trim Adhesive. If it is, then 3M 08984 General purpose Adhesive Cleaner can be used to remove the glue.
http://images.myautoproducts.com/ima...M-8090_TDS.pdf
This adhesive cleaner can be bought at various auto parts stores and it should not dissolve the paint. This stuff might work if the glue is not a 3M product.
https://www.3m.com/3M/en_US/company-...3242391&rt=rud
Sorry Mr. Bobby, it looks like I did not read your post until it was too late. You said the same thing I did.
Money can't buy you happiness but it can buy you car parts which is bout the same thang.
Patrick
Last edited by tp_smith; Dec 18th, 18 at 08:19 AM. Reason: repeat of previous post
tp_smith is offline
post #11 of 16 (permalink) Old Dec 19th, 18, 07:21 AM Thread Starter
Andrew
Andrew69's Avatar
Yesterday I picked up a can of the 3M adhesive remover. Now I need a warm day that I can open the doors for ventilation to try this out. Hope that with some elbow grease this works.
Thank you
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #12 of 16 (permalink) Old Dec 19th, 18, 02:18 PM
Robert
The adhesive remover should work! It sometimes takes multiple tries and lots of elbow grease. If that doesn't work, I have had decent luck with a heat gun. Work in small area and warm the glue up and then scrape it.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #13 of 16 (permalink) Old Dec 21st, 18, 06:42 AM
Bill
I have to remove an adhesive from the dash along the windshield so not sure what to use. It would be easy without a windshield but would like to try before that is necessary
bills69 is offline
post #14 of 16 (permalink) Old Dec 21st, 18, 07:05 AM Thread Starter
Andrew
Andrew69's Avatar
For the benefit for anyone reading; this 3M adhesive remover is highly combustible so using a heat gun with the stuff is not a good idea.
I found just heat did very little to soften the glue. I have not yet had the chance to try the 3M product, but I will report back when I do.
I'm not sure what to say about adhesive under the windshield. What was secured there?
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #15 of 16 (permalink) Old Dec 22nd, 18, 05:05 AM
Bill
you would have to see it to believe it
have you seen some of the old Cheech & Chong movies ?
bills69 is offline
