Glove Box can't open? - Team Camaro Tech
 2Likes
  • 1 Post By Deny411
  • 1 Post By scblucam
post #1 of 10 (permalink) Old Dec 27th, 18, 03:23 PM Thread Starter
Button/lock did work...but now can't open glovebox. I can pull it back about 1/4" and see the lock is not releasing.
Does that catch lever push back or need to be pulled forward or turn to release?
key no longer will turn to lock. Feels like the mechanism broke internally. Push button no longer springs back
Is there a "slim jim" type of procedure to open....or is this a locksmith thing?
Of course this happened when I was getting my proof of insurance out to go register the car.....
SoCal805 is offline
post #2 of 10 (permalink) Old Dec 27th, 18, 04:29 PM
Re: Glove Box can't open?
The catch lever swings down to clear the catch. You can try to reach around from the
back of the glove box.
my 67' build thread:
allanjs is online now
post #3 of 10 (permalink) Old Dec 27th, 18, 04:40 PM
Dennnis Giles
1967 does same, is out of adjustment. I use my disabled parking tag(it hangs from rear view mirrow) to push the lever down.
Pacecarjeff likes this.
Deny411 is offline
post #4 of 10 (permalink) Old Dec 27th, 18, 04:51 PM
Gary
69Z28's Avatar
I've used an inch wide putty scraper or similar to slide down that 1/4" opening and just push the latch/catch down. Should open for you then.
06A 1969 Camaro Z28 711 69 B Black Stripes Console w/tach and gauges
69Z28 is offline
post #5 of 10 (permalink) Old Dec 27th, 18, 06:49 PM
scblucam's Avatar
In the assembly manual pages 41 & 42 show the compartment and lock assembly. It appears the lock arm pivots down from the catch so you may be able to use something like a slim-jim. It would have to be flexible enough to get through the gap but around the body of the door but stiff enough to push the lever down. I have not opened mine in years so memory evades me. I don't have a program here to extract the pages or I would send them. There is a post here with a link where you can download the assembly manual. I will look at mine in the morning. Make sure you are using the correct key. Or you can drill out the lock cylinder and get a new one.
69Z28 likes this.
68 302 M20 3:73 - 85 IROC Z - 82 Honda CB900C
scblucam is online now
post #6 of 10 (permalink) Old Dec 27th, 18, 07:18 PM Thread Starter
Thanks guys. Ironically my Chassis Manual showed up today so I see how the latch catches. Didn't want to pry and scratch up the dash so was asking.
Small thin screwdriver to push the latch forward worked.
Key cylinder is dead
SoCal805 is offline
post #7 of 10 (permalink) Old Dec 27th, 18, 08:02 PM
scblucam's Avatar
Easily available. You may think about all four cylinders. I haven't but they are 50 years old.
Actually five if you count the ignition.
post #8 of 10 (permalink) Old Jan 7th, 19, 01:14 PM Thread Starter
I got a new glove box/trunk lock/keys. I have the "late" 67 tail panel so my lock set for trunk is for 68, large key.
Installed both but the glove box lid does not easily (as it did with old lock) open.
Is there supposed to be some form of spring that pushes it out some?
I do have a switch upper left in the box that my guess is for a glove box light which it does not have that is like a door jam type switch with a light spring button if that doubles as the open assist..
I basically have to push button then use my fingers from other hand to pry/pull the door open
Should the door "pop" open on its own once key lock is pushed in?
I don't see how to adjust, if you can, the top plate the lock catches on.
FWIW in my copy of "assembly manual" page 37 ( not 41-42) shows glove box detail but I am not seeing anything that would act as a "spring" to assist in its opening...other than gravity.
My Assembly Manual is a repop re-print and has no Glossary so basically need to thumb through pages until you see WTF you are looking for
Chassis Service Manual has no interior 411
SoCal805 is offline
post #9 of 10 (permalink) Old Jan 7th, 19, 03:01 PM
The assist comes from the door bumpers. With age they loose their elasticity.
With new bumpers you'll have to slam the door shut. I just changed mine with
Soffseal #1069 from Speedway Motors.
post #10 of 10 (permalink) Old Jan 7th, 19, 03:57 PM Thread Starter
It was the rubber stops that were preventing the door to close unless you really slam it....then to much pressure from the stops was keeping the door pushed back so the lock latch didn't have enough room to release
I pulled out the stops and now the door sits flush but you do have to use your fingers or the key in lock to pull the door open
My intent was to pull the stops out and shave 1/2 the material from them but they both broke on removal. They were fairly hard
Odd the door just does not fall open given its angle. I have played with the angle of the latch plate but no real change
I keep CD's in clove box since they don't fit in console. PIA as I can't open it with one hand.
It's always the small crap. I will try some new stops but will likely have to cut them down some as with them the door stick out to far, does not sit flush
SoCal805 is offline
