1969 Camaro Center Console Install - Team Camaro Tech
post #1 of 6 (permalink) Old Feb 20th, 19, 02:40 PM Thread Starter
Jose
I need some help with installing a center console on my 69 Camaro. I removed the front rug but there is no marking on the floor as to where to mount the console. can someone give me some help as to where to mount it?
Riobeauty is offline
post #2 of 6 (permalink) Old Feb 20th, 19, 02:54 PM
Ed
bertfam's Avatar
Re: 1969 Camaro Center Console Install
You need to look in the AIM, UPC D55, Sheet A2. There are dimples in the floor to show you where to drill.
Ed
Ed B. (but you can call me Bert!)
CRG -
bertfam is offline
post #3 of 6 (permalink) Old Feb 20th, 19, 03:11 PM Thread Starter
Jose
That is what I was looking for when I removed the rug those marking are not there, the floor was replaced but those dimples are not there
post #4 of 6 (permalink) Old Feb 20th, 19, 03:47 PM
Craig
Craig1969's Avatar
Send a message via AIM to Craig1969 Send a message via MSN to Craig1969 Send a message via Yahoo to Craig1969
I had the same issue a few years back. I simply mounted the braces to the console and placed it on the floor....marked it where I thought looked correct (I've owned many 68-69 Camaros so I knew about where). If you are using gauges, make sure you keep it forward enough for the wiring harness to reach the gauges. I am pretty sure the rear courtesy light is seperate from the harness so you don't have to worry about that one. If your car is a 4 speed, make sure reverse and 4th clear the shifter cover plate.
Prepare to be the center of attention when you drive a first generation Camaro. You will be gawked at. Grown men & women will coo like children when you drive past. Children will scream like babies. Dogs & cats will get along. Does it get any better?
Craig1969 is offline
post #5 of 6 (permalink) Old Feb 20th, 19, 04:00 PM
Robert
As mentioned, my 69 is a 4 speed, so I just mocked it up with the brackets in place. Made sure the shifter had full range of motion in all directions, marked it, and drilled the holes. Pretty straight forward.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #6 of 6 (permalink) Old Feb 20th, 19, 04:23 PM Thread Starter
Jose
Thanks Very one for your help
1969 Camaro Service Manuals (3) also a Factory GM Parts Catalog wishfull69 Forum Classifieds 3 Aug 24th, 19 08:00 PM
TMI center console for 1967 Camaro Duneit Interiors 19 Mar 5th, 19 05:51 AM
67 center console and 70 mirrors Duneit Forum Classifieds 4 Jan 23rd, 19 10:31 AM
1968 center console Devor Electrical & Wiring 5 Jan 23rd, 19 02:29 AM
1969 Camaro Firewall install Help Jaymz007 Body Shop 2 Nov 17th, 18 06:33 PM
