Rear bench seat spring measurement. - Team Camaro Tech
 1Likes
  • 1 Post By Larry Madsen
post #1 of 8 (permalink) Old Mar 18th, 19, 07:12 PM Thread Starter
Bryan
Good evening all, I am reupholstering my back seat however when I bought my 68 Camaro with standard interior the bench seat springs were just setting in there and I don' believe they fit right. Does somebody have the measurements for the bottom and top springs without foam. Thanks in advance.
68 Camaro SS
468 VortecPro
M22 Rockcrusher
bhodges061 is offline
post #2 of 8 (permalink) Old Mar 19th, 19, 11:56 AM
Nick
Re: Rear bench seat spring measurement.
there's no foam in the back seat so the spring should go all the way to the side panel
67 rs/ss 350 original eng,700r4, a/c, tilt, deluxe int,strato bench,Ca.emission,front disk,am/fm,floor clock,17" W/V Ralleys,Toyo T1S 255/40/17, 245/40/17
MRCOOL_RSSS350 is offline
post #3 of 8 (permalink) Old Mar 19th, 19, 07:28 PM Thread Starter
Bryan
I thought it was wrong cause it does not reach the sides. Thanks is for the reply.
68 Camaro SS
468 VortecPro
M22 Rockcrusher
post #4 of 8 (permalink) Old Mar 19th, 19, 07:58 PM
Larry
Rear seat for deluxe interior is narrower. Deluxe includes the arm rests which take up the extra space.
Could it be you have a deluxe interior rear seat?
I should note: I am dealing with my 67, which I assume would be the same as 68 in this regard.
My rear seat (for deluxe interior) is not yet upholstered either and the width of the skeletal seat base is just a bit over 46.5"
I can't complain, but sometimes I still do.
Larry Madsen is offline
post #5 of 8 (permalink) Old Mar 19th, 19, 09:38 PM
Garth
67-8 deluxe-standard set-ups are not the same. It all depends on armrest usage...Camaro - Interior Related
IIRC, the wide seat (w/o armrests) is about 4" wider than the narrow seat (with armrests).
Garfields Maro is offline
post #6 of 8 (permalink) Old Mar 20th, 19, 05:35 AM Thread Starter
Bryan
Mine is standard now with no armrest, it could have been deluxe but I bought it with no interior. If it goes all the way to the sides looks like I will have to change it. Thanks for the help.
68 Camaro SS
468 VortecPro
M22 Rockcrusher
post #7 of 8 (permalink) Old Mar 20th, 19, 07:21 AM
Larry
Thanks Garth, I just learned something new.
Garfields Maro likes this.
post #8 of 8 (permalink) Old Mar 20th, 19, 09:53 PM
Garth
There were only 2 widths offered. Larry's narrow seat base is 46.5". If I'm not mistaken, the wide seat is aprox 4" wider (50.5"). What does yours measure ?
Assuming your car isn't a convertible or had a fold down rear seat, it would've had the wide seat with no armrests. Your cowl tag will tell if it was a deluxe or standard interior, but that's irrelevant on the rear seat width for 68 and 69.
1968 Camaro Convertible narrowed rear seat frame spring for mini-tub Ritterc Forum Classifieds 0 Dec 15th, 18 11:55 AM
67 Strato Front Bench seat - help needed! 67moke Interiors 15 Oct 7th, 18 12:30 PM
rear seat brace question general23cmp Convertibles 3 Oct 4th, 18 06:34 AM
1968 1967 Camaro Convertible Front Bench Seat Restored rafab1 Forum Classifieds 0 Jun 24th, 18 06:14 PM
67 Conv Rear Seat Brace install manycj Body Shop 5 Jan 18th, 18 02:19 PM
