Rear Windlace won't fit? 68 Camaro - Team Camaro Tech
 2Likes
post #1 of 17 (permalink) Old Mar 24th, 19, 09:48 AM Thread Starter
Send a message via AIM to Briancp396 Send a message via MSN to Briancp396
I have a 68 Camaro Coupe. Ordered the precut rear windlace with the finished top edge. Windlace fits except for at the top because it's too wide to fit inside the windlace. Am I missing something? See attached picture. Any help will be appreciated, thanks.
68 RS Camaro, 350 cid, 4-speed
Briancp396 is offline
post #2 of 17 (permalink) Old Mar 24th, 19, 10:25 AM
Kevin
KevinW's Avatar
Re: Rear Windlace won't fit? 68 Camaro
Brian, the windlace is not supposed to wrap around the cardboard or the metal top of the interior qtr panel. The interior qtr panel usually has a couple inches of vinyl (seems to be cut off in your pic). That extra vinyl is what is wrapped around the pinch weld (contact cemented) and the windlace gets attached. There should only be the metal pinch weld and two layers of the vinyl for it to cover.
130fe and Garfields Maro like this.
Kevin
KevinW is offline
post #3 of 17 (permalink) Old Mar 24th, 19, 11:03 AM Thread Starter
That makes sense, good thing I just cut the one side. My other side has the extra vinyl. So I need to wrap the extra vinyl around and cement it, then windlace goes over that? Do I need to cut the cardboard back 1/2" so that it's not too think for the windlace?
post #4 of 17 (permalink) Old Mar 24th, 19, 11:04 AM Thread Starter
That makes sense, good thing I just did the one side. This is my other side. So I need to wrap the extra vinyl around and cement it, then windlace goes over that? Do I need to cut the cardboard back 1/2" so that it's not too think for the windlace?
post #5 of 17 (permalink) Old Mar 24th, 19, 02:52 PM
Garth
Correct, the windlace fits over the excess vinyl (and pinchweld) only. It actually butts up to the underlying cardboard. I have this pic handy of the bottom area that might help...
Garfields Maro is offline
post #6 of 17 (permalink) Old Mar 24th, 19, 06:40 PM
Kevin
KevinW's Avatar
Brian, it is a test and fit kinda deal. If the cardboard goes to far forward and interferes with the windlace fully seating, then yes, you can trim a little cardboard to make it fit correctly. Just take your time and measure twice, cut once
Kevin
KevinW is offline
post #7 of 17 (permalink) Old Mar 31st, 19, 03:39 PM
Jose
Is there a special way to install the Windlace or pinchweld? I have tried 3 times to install it on my 69 Camaro and having to purchase new ones each time. This time I am doing it like the people say here on this post not to pinch the cardboard and to use contact cement but the windlace still is not sitting right.
Riobeauty is offline
post #8 of 17 (permalink) Old Apr 1st, 19, 12:35 AM
Garth
Jose, can you post a pic or 2 ? I still have the original windlaces which aren't perfect but fit well. Earlier repros had bad reviews. Not sure if they're any better yet or not ?
post #9 of 17 (permalink) Old Apr 1st, 19, 09:22 PM
Jose
Garth
Hope this picture helps
post #10 of 17 (permalink) Old Apr 1st, 19, 09:28 PM
Jose
Here are more pictures
ID:	226151   Click image for larger version
ID:	226153   Click image for larger version
post #11 of 17 (permalink) Old Apr 1st, 19, 09:41 PM
Garth
Looks like it has the internal metal clip, but the windlace doesn't fit over the end properly. The end of the clip shouldn't be visible as it's suppose be inside the end of the windlace.
That's what I think I see.
edit after additional pics; I think the windlace needs to be twisted down to fit over the clip or possibly the end of the clip needs to be bent down...
post #12 of 17 (permalink) Old Apr 2nd, 19, 08:12 AM
Apprentice
Not to hi-jack this thread and this may be a dumb question but will windlace for a 68/69 fit a 67? I don't like the way the top piece of a 67 windlace fits or looks.
Perry Mitchell is offline
post #13 of 17 (permalink) Old Apr 2nd, 19, 11:27 AM
Jose
So should I start the install at the top and work down? Do i have to squeeze the windlace as I install it?
post #14 of 17 (permalink) Old Apr 2nd, 19, 02:10 PM
Garth
Definitely start at the top. I don't know what it will take to make it fit properly looking at pics. It obviously needs to be pushed in on the bottom edge so it's flush with the panel. The clip may be what's holding it up. May need to remove the screw to see if it will fit better, then make the necessary modifications, adjustments, etc....
post #15 of 17 (permalink) Old Apr 2nd, 19, 02:12 PM
Jonesy's Avatar
I always thought the 69 windlace was different than 67-68. The 69 windlace has a metal tab at the top that extends into the window fuzzie area and is attached there with a screw.
The rear side panel has extra material that wraps around the pinch weld that the windlace goes over. I can possibly get a pic but that covers the 69 only as far as I know.
Team Camaro Gold Member #14
1969 Camaro RS/SS L48 4 speed
Jonesy is offline
Sell or Trade 68 Camaro RS Pro Touring LS motor T56 Magnum Tranny etc. Mark Orgettas Forum Classifieds 0 Jan 7th, 19 04:26 PM
68 Camaro rear bumper goodeye Restoration Corner 16 Oct 12th, 18 08:58 PM
68 Camaro parts etc... 68zz502fi Forum Classifieds 1 Jul 19th, 18 07:34 AM
Rear end for 68 Camaro Black l79 Camaro Tech 4 Mar 30th, 18 06:55 AM
68 camaro rear sway bar alt66 Brakes, Suspension & Steering 8 Mar 11th, 18 09:29 PM
