67 custom gauge cluster - Team Camaro Tech
post #1 of 3 (permalink) Old Mar 27th, 19, 06:03 PM Thread Starter
Probationer
Sharing my idea for a 67 custom gauge console, needed to figure out how to add the fuel gauge to the gauge cluster.
Name:	67 gauge.jpg
67pete is offline
post #2 of 3 (permalink) Old Mar 27th, 19, 08:11 PM
Tom Anderson
Re: 67 custom gauge cluster
What you can do is add a 68 console with the 4 gauges
socal_tom is offline
post #3 of 3 (permalink) Old Mar 27th, 19, 10:39 PM
160 mph speedo and a 10k tach....would suggest a stout build.
it's your car so put it anywhere.
As mentioned you could go to a later gauge face for 4 or any of several aftermarket multi gauge face plates.
Or, what I did, was do a 3 gauge pod (AutoMeter) bracket/gauges under the center dash. Given you swapped in dedicated speedo and tach in the 2 stock holes....you might also want, beyond fuel, oil pressure and water temp
I still have the stock 67 base cluster so went tach, OP, water temp in the 3 gauge under dash. My idiot lights are also still enabled.
SoCal805 is online now
1967 Camaro RS/SS LS3 1LE T56 for sale $99,900 dsavage30 Forum Classifieds 1 May 22nd, 19 07:10 AM
69 Camaro Center Fuel gauge not accurate travisch Electrical & Wiring 0 Sep 11th, 18 03:26 PM
67 center gauge cluster help abstron Electrical & Wiring 2 Apr 9th, 18 08:03 PM
67 Tach speedo cluster 3d cad Restoration Corner 0 Mar 31st, 18 05:28 PM
Horn Relay location? Larry Madsen Restoration Corner 17 Jan 5th, 18 07:53 PM
