Gauge Suggestions - 1968 SS - Team Camaro Tech
 3Likes
post #1 of 17 (permalink) Old Mar 28th, 19, 02:08 AM Thread Starter
majj
Hey all, so I just finished with my LS2 build. I had a 350 previously, and I believe my gauges are Autometer.
Anyways since everything is hooked up on computers, the gauges are going crazy and I think it's time for something new. I prefer standard gauges vs digital dash
Can anyone give me suggestions on what would fit my 68? and if you have a direct link .. thank you
https://youtu.be/UY2GWzlRgHE
Sent from my iPhone using Tapatalk
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is offline
post #2 of 17 (permalink) Old Mar 28th, 19, 04:03 AM
Vega$69's Avatar
Re: Gauge Suggestions - 1968 SS
I would take a look at Autometer.
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #3 of 17 (permalink) Old Mar 28th, 19, 04:18 AM Thread Starter
majj
I Like this one, wondering if it's a direct fit without having to get the LS2 install kit which comes separate.
https://www.autometer.com/6-gauge-di...ltra-lite.html
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is offline
post #4 of 17 (permalink) Old Mar 28th, 19, 06:19 AM
Vega$69's Avatar
I used that set in a 67 years ago.
I actually like the Dakota Digital VHX a lot better.
1967- 68 Camaro/ Firebird VHX Instruments
Smoothdawg likes this.
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #5 of 17 (permalink) Old Mar 28th, 19, 08:02 AM
If I were building a car today I wold use a digital dash only because it allows data recording. I much prefer mechanical gauges that work with the ignition off.
If you were to use a set up as above it will work fine (not interfere with the computer) with all Mechanical gauges. I had a full set of Autometer 270 degree sweep mechanical black faced (because I drove mostly in daylight) Pro Comp gauges in my last car with the only electrical gauges being the Tachometer, voltage, air/fuel, and exhaust gas temp.
Big Dave
Larger Dave is offline
post #6 of 17 (permalink) Old Mar 28th, 19, 08:20 AM
I'm with Dave - mechanical gauges. Keep period correct - S&W = Stewart Warner.
post #7 of 17 (permalink) Old Mar 28th, 19, 11:31 AM
Chris
130fe's Avatar
Cool Re: Gauge Suggestions - 1968 SS
I love the Dakota digital gauges in mine. I have had the VHX and now the HDX series. They even have a RTX series that is very retro. Connect the gauges with the PCM via their OBD2 BIM module.
Camaro
OBD-II / CAN Interface
Really easy stuff.
Chris
1968 Camaro SS coupe, Lemans Blue/medium blue interior
LS3/T56 Ridetech Suspension
130fe is offline
post #8 of 17 (permalink) Old Mar 28th, 19, 02:13 PM Thread Starter
majj
I like the dakota’s too but prefer the 6pc gauges like the autometer.
I was told i need the LS install kit with that
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is offline
post #9 of 17 (permalink) Old Mar 28th, 19, 03:12 PM
Vega$69's Avatar
Yes those parts are metric adapters for the LS engine and the resistor is needed so the tach will work.
AutoMeter's GM LS engine gauge installation kits feature specialized components to ease the installation of an LS engine into your ride. AutoMeter has done the legwork for you and includes a full color installation guide that not only details the use of the included metric adapter fittings, short depth water temperature sensor, and tachometer resistor, but also covers installation procedures for other commonly monitored parameters.
Each kit includes:
* 12mm x 1.5 to 1/8 in. NPT adapter
* 16mm x 1.5 to 1/8 in. NPT adapter
* Low profile electric temperature sender
* 10K 1/2 watt resistor (tach function)
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #10 of 17 (permalink) Old Apr 7th, 19, 12:40 AM Thread Starter
majj
Thank you. Just wanted to make sure since the mechanic said it looked short for my 6speed.
1968 Camaro SS
LS2/T56
RideTech StreetGrip
majj35 is offline
post #11 of 17 (permalink) Old Apr 7th, 19, 03:45 AM
Vega$69's Avatar
The adapters have nothing to do with the transmission?
69 Z28(Sold)
(SOLD)
Vega$69 is offline
post #12 of 17 (permalink) Old Apr 7th, 19, 06:42 AM
Beth
I like the "period look" of SW gauges under the dash with an old-school tach on the column- unless you can afford the factory in-dash tach.
If you have the cash, Vegas's recommendation looks the closest to stock to me; I like it a lot. Can't stand digital gauges !
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #13 of 17 (permalink) Old Apr 8th, 19, 01:34 PM
Apprentice
I'm putting Dakota RTX Gauges in my 68. Should have pictures in about 6 weeks.
Eric
130fe likes this.
pnd4pnd is offline
post #14 of 17 (permalink) Old Apr 10th, 19, 02:26 PM
Apprentice
Ron
I used the New Vintage 68 Series gauges in my 68. They have a similar look to the stock gauges but give you all the information you need right there in front of you. Kind of retro but modern.
Ron
Ron's 68 is offline
post #15 of 17 (permalink) Old Apr 10th, 19, 03:43 PM
Milt
Milt's 68 SS/RS 396's Avatar
Here is what I did. Carbon fiber dash carrier with stock gauges.
Name:	Carbon Front.jpg
ID:	226381   Click image for larger version
Go big, or stay Home!
Milt's 68 SS/RS 396 is offline
NEW - Dakota Digital RTX Series Gauge Systems - MUST SEE! MCB Sponsors 2 Dec 9th, 19 01:01 PM
An Evolving Problem CityguyUSA Engine 10 Dec 31st, 18 07:52 AM
69 Camaro Center Fuel gauge not accurate travisch Electrical & Wiring 0 Sep 11th, 18 03:26 PM
Horn Relay location? Larry Madsen Restoration Corner 17 Jan 5th, 18 07:53 PM
