Adhesive for sound deadening? - Team Camaro Tech
post #1 of 7 (permalink) Old Apr 12th, 19, 07:41 AM Thread Starter
Apprentice
Hey guys....getting ready to do the sound-deadener in my car this weekend. The rolls I have, have been sitting around for a number of years and they have lost their tackiness. I figure there still has to be a way to apply the sheets with maybe a spray adhesive or brush-on adhesive? I don't want it to be permanent just enough to have a secure hold and be able to peel off should I ever need to. What products do you guys recommend? Thanks.
1968 Pro-Touring Camaro. LS1/4760E. With '67 Tail lights and a '70 rear view mirror...cause I'm weird like that.
trapin is offline
post #2 of 7 (permalink) Old Apr 12th, 19, 08:41 AM
Robert
Re: Adhesive for sound deadening?
Are you just doing floors and doors? I would think hitting it with a heat gun would bring back some of the tackiness. Just about everything is going to be held in place by a seat or a door panel. If it is not holding in place, maybe try a little bit of the upholstery spray on glue. Also use some painters tape to hold it in place while you are working on it.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #3 of 7 (permalink) Old Apr 12th, 19, 08:59 AM
3M Super 77 spray can
as mentioned a heat gun may "wake up" the adhesive but if you feel you need something extra the 3M stuff works great
SoCal805 is online now
post #4 of 7 (permalink) Old Apr 13th, 19, 04:19 PM
I would definitely recommend using a strong spray glue if you're planning on using it in the doors. Everytime you shut the door it'll want to fall off. Ask me how I know. If using it under the carpet the juting and carpet will hold it in place. As you drive your car on hot days and heat from under the car permeates up through I would think the glue would start activating. I've had fresh stuff fall off vertical surfaces when not applied properly.
1967 Camaro
383 stroker
Automatic
Duneit is offline
post #5 of 7 (permalink) Old Apr 13th, 19, 06:38 PM
Aside from the 3M stuff... the company that makes that Magic Sealer stuff you see on TV 24/7 now has a spray on adhesive IIRC.
'69 LeMans Blue Coupe, White Interior, 030" over 454, Super T10 4-Speed, Holley 4150, Pertronix Ignition
CompCams XS274S, 781 Oval Port Heads, PYPES Full 3" SS Exhaust, Hooker Comp Headers, Wilwood Calipers/MC
JGC Steering Box, Helix Uppers/Lowers, ProForged BJs, SpeedHut Gauges, MOMO Steering Wheel, Budnik 17" Wheels
57vette is offline
post #6 of 7 (permalink) Old Apr 13th, 19, 08:25 PM
Vega$69's Avatar
Heat gun. Apply as you normally would then hit with heat gone and a roller. It will stick well without adding another adhesive
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #7 of 7 (permalink) Old Apr 14th, 19, 06:53 AM
USN1969SS's Avatar
I did not want permanent or the mess of scrapping off old glue so I used carpet tape. I did not do vertical (doors), just the floor and center hump so not sure in the long run how it would hold but it has been about seven years and tape still holding.
1969, 350 "Beast", M20, Nothing Fancy, Nothing Pretty, But Sure is Fun!
USN1969SS is offline
Sound deadening ???? Just 1 More Interiors 32 Mar 24th, 20 03:38 AM
Sound deadening in doors? thesanz Interiors 7 Apr 1st, 19 07:26 PM
Trouble with 3M Wearther Strip Adhesive daven1256 Body Shop 13 Nov 6th, 18 07:16 PM
