Headliner Retaining Strip Clips... - Team Camaro Tech
 1Likes
  • 1 Post By allanjs
post #1 of 6 (permalink) Old Apr 24th, 19, 02:59 PM Thread Starter
Apprentice
Guys.....how the hell do I get these suckers on??!! By the looks of one of the old clips (which I'm holding) I'm guessing it compresses into the hole. I am putting as much force as I can on it to no avail. These are for the rear retaining strip that holds the windlass for the headliner. I am trying to install the 3-piece strip. What can you tell me about these? Thanks.
ID:	226689   Click image for larger version
1968 Pro-Touring Camaro. LS1/4760E. With '67 Tail lights and a '70 rear view mirror...cause I'm weird like that.
trapin is offline
post #2 of 6 (permalink) Old Apr 24th, 19, 03:20 PM
Re: Headliner Retaining Strip Clips...
Pull the center pieces up. Shove in the hole and tap the center pieces in.
Refer to post #9 here for pics.
https://www.camaros.net/forums/23-in...r-install.html
my 67' build thread:
allanjs is online now
post #3 of 6 (permalink) Old Apr 26th, 19, 06:11 AM Thread Starter
Apprentice
Thanks for the reply but I don't know what you mean by "Pull the center pieces up". Also....they don't just tap into the hole. I've hit them about as hard as I feel comfortable with but I have my rear window in the car and I'm afraid of cracking it having to use that much force on my swings. Unless I am just TOTALLY getting this wrong. I looked in the other thread but they only talk about removing the clips.
I dunno.....I think I'm just going to use trim screws with the broad flat heads and be done with it. I think the clips might require a special tool and that process has to happen before the glass is in.
trapin is offline
post #4 of 6 (permalink) Old Apr 26th, 19, 07:57 AM
Roger
rogerh's Avatar
Itís possible you may be talking about a different kind of clips. The clips Al is talking about look like a small, double thickness of metal, clip. These stock kind of clips can be removed by working up the top layer of metal at the center with a small screwdriver.
I destroyed several of these stock clips before figuring out how to remove them. The ones I destroyed I replaced with pop rivets. The heads of the pop rivets were flatter than the screws and I didnít want them showing once the headliner was installed.
Roger
rogerh is offline
post #5 of 6 (permalink) Old Apr 26th, 19, 08:58 AM
The one in your first pic looks like a new one that hasn't been installed yet. You would slide that through the hole in the strip into the hole in the body like you have it and tap the center in. Tapping the center in spreads the tangs and that's what holds it in. Looks like you just need to tap it a little harder. The second pic looks like one that was installed already and needs to be "reset" by pulling out on the center part or replaced.
'69 SS396 X66 L34 08D M21 BS
460ci Gen VI 9.75:1 AED 950 carb
Semper Fi!
HawkX66 is offline
post #6 of 6 (permalink) Old Apr 26th, 19, 07:22 PM
They are the same clips as I linked to in my 1st post. Dave's explanation is spot on.
HawkX66 likes this.
My 67 L78 Build Sosh67 Build Projects 253 Apr 13th, 20 07:46 PM
Early 67 chrome headliner side trim clips ? paulmanta Interiors 12 Apr 20th, 19 06:24 PM
Distinctive Industries brand headliner - need some opinions !!! daven1256 Interiors 3 Nov 6th, 18 05:27 PM
Blow out molding clips Rd Hugr 68 Restoration Corner 1 May 5th, 18 08:22 PM
Front Glass, trim clips, rookie mistake. paulmanta Restoration Corner 5 Mar 13th, 18 10:43 PM
