interior gutted-dash install help - Team Camaro Tech
 3Likes
  • 3 Post By ZLP955
post #1 of 11 (permalink) Old May 4th, 19, 09:51 AM Thread Starter
Rich
I have searched here and google - trying to find a list of whats first, next and so on
my 69 is gutted and ready to start installing firewall pad, kick panels, steering column ect I know I had seen the parts listed in order and I sure cant find it now
69 R/S Z/28 302 X33 D80 late 09C
69 T/A clonification LS6-6speed under construction
15 ZL1
64 Chevelle wagon 6.0l planned sons toy
zman1969 is offline
post #2 of 11 (permalink) Old May 4th, 19, 10:44 AM
Re: interior gutted-dash install help
Firewall pad
AC
Brake pedal carrier
Fuse block
Dash gauge carrier
Steering column
Brake booster etc
Carpet
Kick panels
E brake pedal
That what I can think of off the cuff
Edit, fixed per Al.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #3 of 11 (permalink) Old May 4th, 19, 02:26 PM
I'm not sure on a 69 but on a 67 the parking brake pedal/assembly is in the way when
installing the kick panel. Also it's helpful if the heater box isn't installed when installing
the right side kick panel. Don't trim the carpet edges (sill plate) until the console and
seats have been installed. Factory correct is the seats bolt directly to the floor not on top
of the carpet. The rearward edge of the front carpet covers the front seat bolts. The rear
carpet should be cut with a flap to cover the rear bolts.
my 67' build thread:
allanjs is online now
post #4 of 11 (permalink) Old May 4th, 19, 02:46 PM
Listen to Al, I never use those pesky factory kick panels. I like the ones from The Shop LLC and block off the vents.
post #5 of 11 (permalink) Old May 4th, 19, 02:48 PM
jerry
Put the heater defrost duct in after the firewall pad, I believe GM built the car around it
jerry67 is offline
post #6 of 11 (permalink) Old May 4th, 19, 02:50 PM
I assumed Rich has Vintage Air so sequence is a little different, it goes in with AC per their instructions.
post #7 of 11 (permalink) Old May 4th, 19, 05:42 PM
Tim
https://www.camaros.net/forums/34-re...-sequence.html
zman1969, dhutton and allanjs like this.
1969 04A Van Nuys-built Z/28. Cortez Silver with dark blue interior and VE3. Sold Clippinger Chevrolet. Raced at Lions in LA.
ZLP955 is online now
post #8 of 11 (permalink) Old May 5th, 19, 10:52 AM Thread Starter
Rich
I freaking knew this thread was here! and i searched and searched and that thread never showed but one about a Momo steering wheel did like 4 or 5 times
thank you for that
I will be doing a vintage air or similar so if you dont put factory type Kick panels how do you get fresh air in the car? - suggestions?
15 ZL1
zman1969 is offline
post #9 of 11 (permalink) Old May 5th, 19, 11:50 AM
thank you for that
You donít really want fresh air because the VA canít cope with it. You can always crack the window....
Best to install the VA before the fenders go on.
post #10 of 11 (permalink) Old May 9th, 19, 05:00 PM Thread Starter
Rich
OK Don care to elaborate? I know were in Texas and A/C is mandatory when you get older, I guess I'm not up to speed on modern builds - seriously this (modern ventilation) is new stuff for me and it never gets any love from the press in magazines
15 ZL1
zman1969 is offline
post #11 of 11 (permalink) Old May 9th, 19, 05:43 PM
Vintage Air will only cool when recirculating the cabin air. It canít cool adequately with outside fresh flowing into the cabin. Itís mostly about the small sized evaporator. Humid fresh air only aggravates the situation.
Specific dash light assistance Bigbaddad Electrical & Wiring 5 Mar 7th, 19 07:31 PM
OER Dash Carrier Mystery? 4Tundra Interiors 5 Mar 3rd, 19 01:17 PM
Having Trouble finding the correct Gloss for my Dash and Column ryeguy2006a Body Shop 6 Jul 8th, 18 07:31 PM
Help with new dash panel install after poor install briand069 Body Shop 1 May 25th, 18 07:40 AM
VA center dash AC vent DT Heating & Cooling 6 Jan 11th, 18 07:29 PM
