Kick Panel Holes - Team Camaro Tech
post #1 of 4 (permalink) Old May 8th, 19, 08:27 AM Thread Starter
Apprentice
Pete
Kick Panel Holes
I just ripped out my kick panels off my 68 with AC. I don't plan on putting the original AC unit back (will go with a vintage air later), but was wondering about the vent holes. Can I just seal the hols where the kick panels rested?
I will put the kick panels back, but cut the section that rests inside the hole, the section that prevents the water from coming in.
theitalianflip is offline
post #2 of 4 (permalink) Old May 8th, 19, 09:46 AM
Robert
Re: Kick Panel Holes
I don't see why not if you going with the Vintage Air. You can cut a thin piece of metal in an oval slightly larger than the opening and use some seam sealer or gasket sealer of some sort.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #3 of 4 (permalink) Old May 8th, 19, 11:02 AM
Beth
Go ahead and download the instructions for the vintage air kit. They tell you how to deal with everything.
68 Camaro convertible, 6.0 LQ4 with LS3 heads, Vintage Air, 750 street demon carb, eddy perf rpm, GM hot cam, Hooker headers, 4L80e, 12 bolt, 3.55 gears
NashvilleCat is offline
post #4 of 4 (permalink) Old May 8th, 19, 01:27 PM Thread Starter
Apprentice
Pete
Thanks for the advise.
Tags
kick panel
Vintage Air Kick Panel Modification ssanto Heating & Cooling 4 Nov 22nd, 18 04:08 PM
Installing kick panel speakers Winch Electrical & Wiring 5 Sep 9th, 18 07:41 PM
Speaker Install ... Kick Panel Larry Madsen Interiors 1 Jun 4th, 18 01:35 PM
1969 camaro kick panel with a/c cable route help camaro69ss572 Restoration Corner 0 Mar 20th, 18 10:39 AM
Driver side kick panel vent John_D Heating & Cooling 6 Feb 23rd, 18 05:18 PM
