drivers door stuck - Team Camaro Tech
 1Likes
  • 1 Post By Charles Martin
post #1 of 7 (permalink) Old May 13th, 19, 03:17 PM Thread Starter
drivers door stuck
Hi, my drivers door on the 67 Camaro HT is stuck closed and can't get it open. Tried recycling the lock couple hundred times, acts like it is working properly. tried prying it open from the outside, tried kicking it open from the inside. The outside handle feels like the lock is working and can tell the difference from locked and unlocked. in the door knob outside. Have the door panel off and things that I can see seem to be ok. SO where do I go from here to get this door open. Even tried jacking it up at the rear of the sub frame and nothing. The screws from the latch are on the outside in the jamb where can't get at them. So how do I get this door open and what is the likely cause. If pry just where is best spot to pry on
Thank You
Charles
Charles Martin is offline
post #2 of 7 (permalink) Old May 13th, 19, 03:45 PM
Re: drivers door stuck
remove interior door panel and then follow the arm that attaches to the inside door handle and see/feel if it is engaging the linkage/door latch mechanism. The door latch mechanism may have broken keeping it on the striker
You may likely need to pull DS seat to access the door panel with the door closed. Yeah this is a PIA when the door won't open
IDK if this is a door lock thing and a locksmith could help
I don't think "prying" anything is the answer....without causing body damage
SoCal805 is offline
post #3 of 7 (permalink) Old May 13th, 19, 07:28 PM Thread Starter
looks like the spring on the paddle is ok and everything seemed to be working as it should as in inner and outer door handle and the lock mechanism. Was able to go in and use an allen wrench and loosen up the striker, but door still was not opening. was able to pry on door from outside about where striker was and able to pop the door open. Now to figure out whats not working right, any ideas welcome
Charles
post #4 of 7 (permalink) Old May 13th, 19, 07:36 PM
69-Pace's Avatar
Charles - More common than you would think. Here is a search of the archives here:
https://www.camaros.net/forums/gtsea...q=door%20stuck
Super Moderator Team Camaro
to send me a private message
69-Pace is offline
post #5 of 7 (permalink) Old May 14th, 19, 06:14 AM
Bruce
I would replace the lock mechanism. . . . .about $60, you will spend that much on beer trying to figure it out, been there done that.
The Camaro Guy is offline
post #6 of 7 (permalink) Old May 14th, 19, 08:49 AM
Cool Re: drivers door stuck
Make sure the car is not on 4 jack stands ON THE FRAME. I know sounds strange, but it will do that. If you put the back two under the rear axle, you won't have that problem !
TJS69 is offline
post #7 of 7 (permalink) Old May 15th, 19, 12:43 PM Thread Starter
The problem looks to have been the striker was hitting the lower part of the latch and peened a bit making it wider and resulted in the release piece sticking and not releasing. Also seems that we bent the release arm at the door handle and it wasn't pushing it in far enough to compound the problem after the door stuck closed. A little dremel work and a little bending along with a little grease and door is now opening and closing smoothly.
69-Pace likes this.
Drivers Side Carpet Getting Wet Hawkdriver Fourth Generation 2 Jan 10th, 08 05:16 PM
Drivers rear light issue - no:brake, turn, or flasher Rascal Electrical & Wiring 1 Aug 11th, 07 04:49 PM
Drivers window adjust question 69rag327 Interiors 3 Mar 24th, 06 06:26 PM
68 Still leaning drivers side??? Badcaiman Tech 2000 16 Jul 12th, 01 03:41 PM
68 Camaro leaning on drivers side??UPDATE?? Badcaiman Tech 2000 5 Jun 11th, 01 06:06 AM
