Morris Classics seatbelts don’t fit - Team Camaro Tech
 1Likes
  • 1 Post By morrisclassic
post #1 of 11 (permalink) Old May 25th, 19, 08:56 AM Thread Starter
Apprentice
I have Corbeau Seats and the Morris Classics seatbelt kit just doesn’t fit with them. It’s like the seat is too wide for them. Can’t get the seat back far enough. I even adjusted the arms to no avail. Anyone else have this problem? Possible solution? Am I just gonna have to use stock lap belts?
ID:	227195   Click image for larger version
ID:	227197   Click image for larger version
1968 Pro-Touring Camaro. LS1/4760E. With '67 Tail lights and a '70 rear view mirror...cause I'm weird like that.
trapin is offline
post #2 of 11 (permalink) Old May 25th, 19, 10:31 AM
Steven
stamatisg1977's Avatar
Mine didnt fit well with stock seats either
The retracter box is just too big
69 Frost Green Camaro
LS3 with TSP stage 3 cam
Tremec TKO 600
Ridetech rear 4-Link
Follow my journey here:
stamatisg1977 is offline
post #3 of 11 (permalink) Old May 25th, 19, 10:55 AM
DjD
DjD's Avatar
Re: Morris Classics seatbelts don’t fit
Call Morris Classic's and talk to Billy, he may have something that moves the take-up real back behind the seat.
...Dennis
DjD is offline
post #4 of 11 (permalink) Old May 25th, 19, 10:55 AM
Pretty sure he has brackets that will allow them to fit. Contact him and he will set you up.
1959 El Camino project
1957 Buick Caballero project
dhutton is online now
post #5 of 11 (permalink) Old May 25th, 19, 04:08 PM
Billy Morris
Morris Classics seatbelts do fit
Morris Classic seat belts are designed to fit stock interiors and are year & car specific.
Added sound deadener and non stock seats do present problems.
We offer brackets that set the reel rearward 6.5" & 9".
Contact us after Memorial Day
Billy
morrisclassic is offline
post #6 of 11 (permalink) Old May 26th, 19, 09:46 AM
Jeff
Re: Morris Classics seatbelts donít fit
Maybe it's just the pictures? When I installed mine I was concerned the interior door panel was going to hit the retractor (I had read where it had hit on other installs). Mine clear the panel by about a sheet of paper, close but no contact. Yours look to be a pretty good distance away from the interior door panel. Not sure what's causing that? Wonder if you have the correct parts?
SC42 is offline
post #7 of 11 (permalink) Old May 26th, 19, 10:58 AM
Billy Morris
Anything added to the floor pan will decrease the clearance between the seat & retractor.
In a factory carpet & jute mat configuration there is an 1/16" to 1/8" clearance between the retractor,
door & seat.
Billy
post #8 of 11 (permalink) Old May 31st, 19, 03:09 AM
JB
Billy, You mentioned there could be an issue with sound deadener on the floor pan.
I havenít installed my Morris seatbelts in my 69 Camaro restoration yet. I do have Dynomat extreme put on the floor pan and Iím about to put in the standard type carpet with jute. Is there something I should do around the seatbelt area (like cut away the Dynomat) for extra clearance before I install my carpet? Thanks.
4Tundra is offline
post #9 of 11 (permalink) Old May 31st, 19, 10:08 AM
Billy Morris
JB,
I would remove some of the jute to be the same thickness
as factory underlayment leaving the Dynomat. Because the
Dynomat has a better sound & heat rating than the jute.
Thank You for purchasing our seat belts!
If you have another questions call us
Thx, Billy
4Tundra likes this.
post #10 of 11 (permalink) Old May 31st, 19, 06:40 PM
Jeff
Billy, Did the original poster ever get straightened out? Those retractors are different than the ones in my 68 camaro. My lap belt does not go directly into the retractor, there is a metal arm off the retractor it attached to. I think he has the wrong parts.
I like mine so much I just want to be sure he is working with the right parts.
Thanks again,
SC42 is offline
post #11 of 11 (permalink) Old Jun 1st, 19, 05:12 AM
Billy Morris
Jeff,
He has the metal bracket vertical behind the reel instead of pointing to the front as it should be to go over your lap.
I think he called and ordered the brackets that relocate the reel backwards and inward.
Billy
1969 firebird convertible with photos tp_smith Build Projects 467 Yesterday 05:31 PM
Custom fit carpet floor mats by Lloyd carid CARiD.com 0 Oct 30th, 14 07:20 AM
Morris Classics seat belt install question pdmracing Interiors 16 Jan 20th, 13 07:15 AM
new style morris seatbelts now availble! (pics inside) c6matt Interiors 4 May 30th, 10 05:51 AM
