A/C drain port - Team Camaro Tech
post #1 of 2 (permalink) Old Jul 20th, 19, 06:17 PM Thread Starter
Probationer
A/C drain port
Water is beginning to come through my vents and is now pooling in the floorboards of my vehicle. I suspect a clogged drain port but in all honesty I have no clue where on earth it is located. Help?
btapiaa is offline
post #2 of 2 (permalink) Old Jul 21st, 19, 11:54 AM
Russ
Re: A/C drain port
It's at the very bottom side of the "suitcase" under the hood, along the seam where the two halves join. Best to put it up on a lift if possible. If you have an AIM see UPC C60 Sheet D1. It's about an inch in diameter rubber and designed to stay shut until water enters it. Any chance the water is due to abnormally hot weather along with very humid air? Seems you'd need to have a lot of water in there to come out the vents.
Petes L48 is offline
