67 Camaro door glass help - Team Camaro Tech
post #1 of 6 (permalink) Old Jul 29th, 19, 05:15 AM Thread Starter
Probationer
Brent
Working on the glass for my 67. It seems fairly tight when I roll it up, especially when it gets closer to the top it even tries to raise the vent window up. It looks like the glass in the vent channel is really tight toward the outside of the car, it digs into the vent weather strip. No matter the adjustment I make has no effect. The part on the window sash channel that glides in the vent window channel is straight, would it help to bend it a little to the contour of the vent window? I've watched all the youtube video's but haven't seen how diagnose a tight window.
67Camarolsx is offline
post #2 of 6 (permalink) Old Jul 29th, 19, 07:04 AM
Re: 67 Camaro door glass help
It shouldn't be necessary to bend that piece and I doubt you can. Have you changed anything
such as the vent window channel run felt, vent window frame, glass, etc.? Here's a couple of
pics of a drivers window and rear track I sold a while back. They might help you.
my 67' build thread:
allanjs is offline
post #3 of 6 (permalink) Old Jul 30th, 19, 01:48 AM Thread Starter
Probationer
Brent
Thanks for the pictures. They are new vent window frames and felt, all new glass from Pilkington. Made some adjustments last night and seemed too have gotten a little better. Still a little tight but better.
post #4 of 6 (permalink) Old Jul 30th, 19, 11:05 AM
OP
IDK if any of this will help but in my search for "how to" on rear 1/4 glass I found this guys videos helpful
https://www.bing.com/videos/search?q...6761&FORM=VIRE
This is his vent glass install video
https://www.bing.com/videos/search?q...6EFE&FORM=VIRE
SoCal805 is offline
post #5 of 6 (permalink) Old Jul 31st, 19, 11:05 AM
Greg
pittpens24's Avatar
Is the glass new?
I bought all my glass from Metropartsmarket.com because I wanted smoked glass. Had all kinds of issues to find out that the glass had too much of a curve. Could not return it, had it for almost a year before I fit it
'68 Camaro with RS conversion
Moser 9" with 4:11
Tremec T-56 Magnum 6 speed
572 BB - CM Engines
pittpens24 is offline
post #6 of 6 (permalink) Old Aug 11th, 19, 05:47 PM Thread Starter
Probationer
Brent
Sorry just seen this. Glass is all new. Purchased from Pilkington.
