Headliner installed! - Team Camaro Tech
 6Likes
  • 3 Post By patman2
  • 3 Post By patman2
post #1 of 14 (permalink) Old Aug 4th, 19, 09:14 PM Thread Starter
Pat
I installed my headliner today, glad to have that behind me!
I ended up with a few ripples, hopefully some time baking in the sun will take care of those.
130fe, rogerh and 350sshugger like this.
Pat - 68 Camaro Coupe -
patman2 is offline
post #2 of 14 (permalink) Old Aug 5th, 19, 04:30 AM
Re: Headliner installed!
Wrinkles will not come out unless you manipulate the headliner.
Call for restoration and custom paint scheduling:
Sauron67MM is online now
post #3 of 14 (permalink) Old Aug 5th, 19, 05:02 AM
Ed
That's the one thing I hate installing is a headliner. Can never get it right!!! Ugh! Good luck!!!!!
ZEN357 is offline
post #4 of 14 (permalink) Old Aug 5th, 19, 12:02 PM
Roger
rogerh's Avatar
Scott, the wrinkles came out of mine without manipulation or using a heat gun. If the OP has it glued and the trim all on I would recommend giving it a little time to see whatís going to happen.
Roger
rogerh is offline
post #5 of 14 (permalink) Old Aug 5th, 19, 12:41 PM
headliner install is way above my pay grade but seeing various "build a car" shows the interior guys seem to always use a "steamer" on headliners to coax out wrinkles.
I see OP has paper clips holding the headliner in place...maybe some more "tug" sideways in the areas affected will pull the wrinkles out then secure with whatever fastener headliners are held in place with.
But again I have never done a headliner install so just making a guess. Kudos to OP for even doing this yourself.
SoCal805 is online now
post #6 of 14 (permalink) Old Aug 5th, 19, 12:59 PM
Mine wasn't wrinkled but I would say it was maybe a bit "loose" so I mist sprayed it with water and rolled up the windows and set her out in the Texas sun and it "tightened" up nicely.....Still tight 20 years later.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #7 of 14 (permalink) Old Aug 5th, 19, 07:17 PM Thread Starter
Pat
Good tip on the steam and mist+sun ideas, may give that a try. This was my 3rd time installing a headliner, it actually went smoother than I remember the last one going about 10+ years ago.
It ainít perfect but it beats the heck out of the bare metal that was there before! Not too shabby for a can of spray adhesive, a few boxes of binder clips, and a few choice words!
rogerh, pietenpol and Shannon4570 like this.
patman2 is offline
post #8 of 14 (permalink) Old Aug 6th, 19, 03:49 AM
Roger
The OP's picture shows numerous wrinkles that are normally non-existent after installation. Lay the headliner out under the influence of heat to relax it prior to installation. Slice the sleeves correctly to allow proper stretching. Very little reason a first timer can't have a wrinkle free installation.
post #9 of 14 (permalink) Old Aug 6th, 19, 03:59 AM
keith
X-77 keith's Avatar
What Scott said about slicing the sleeves to get a good pull is a very good tip. I use the paperclip method too. But I use the glue you put on with a brush. It's easier to use for me, and less mess in my opinion. Your not far off. You can get those out relatively easy.
X-77 keith
X-77 keith is offline
post #10 of 14 (permalink) Old Aug 6th, 19, 05:23 AM
Vega$69's Avatar
As stated above you have to slice the sleeves. All of the headliners Iíve seen the sleeves are stitched too long. Unless you slice them you can pull all day long and youíll never get the wrinkles out.
Vega$69 is offline
post #11 of 14 (permalink) Old Aug 6th, 19, 05:36 AM Thread Starter
Pat
Agreed on the sleeves... theyíre always too long. I trimmed mine back a fair amount during the install.
patman2 is offline
post #12 of 14 (permalink) Old Aug 6th, 19, 07:50 AM
Roger
rogerh's Avatar
Scott, you have a great technique installing headliners and I am sure they all look great. I am not disputing your technique at all.
The OP said he was finished with the installation and the picture in his post is clearly not the the finished product. I was just stating my experience and encouraging him to see what sun's heat would do before doing anything more drastic.
Roger
rogerh is offline
post #13 of 14 (permalink) Old Nov 6th, 19, 05:09 AM
Ryan
What are people using for the pinch welds? I saw a roll of 25 ft of just generic pinchweld on eBay for $30-40 bucks. I know there is a kit on carmarocentral, but I have a hard time paying almost $200 for the pinch welds.
Project: 1968 Camaro LS1, T56, Z51 brakes, 12 bolt, etc.
ryeguy2006a is offline
post #14 of 14 (permalink) Old Nov 6th, 19, 07:38 AM
Roger
rogerh's Avatar
The headliner pinch weld covers are specially designed for that location. On the inside they are flat and the outside they are thicker to fill a cavity between the pinch weld and the weather striping. The headliner covers also have a different texture.
Roger
rogerh is offline
