Console Shifter Plate - Team Camaro Tech
 3Likes
  • 1 Post By akxtreme
  • 1 Post By RDW
  • 1 Post By TJS69
post #1 of 12 (permalink) Old Aug 21st, 19, 06:14 AM Thread Starter
Apprentice
Justin
I am in the process of building a 68 RestoMod and trying to keep the interior somewhat stock in appearance. One item I can not get over is the wood grain on the console shifter plate. I am replacing the center dash panel with a black pebble grain insert to remove the woodgrain from it.
My issue is that I can not find anything to replace the woodgrain on the console. Ideally I would like to replace it with the same pebble grain that is all over the rest of the console and dash, but I can not find sheets of it anywhere. I have also considered using vinyl wrap over the woodgrain to change the appearance, but not sure how this would look with the rest of the car.
So I was wondering what everyone else is doing? Any pictures? Do they sell the pebble grain in sheets anywhere? All help would be greatly appreciated.
'68 Camaro Base, '35 2dr Sedan, '34 3w Coupe, '57 Chevy Pickup
Senior31 is offline
post #2 of 12 (permalink) Old Aug 21st, 19, 06:25 AM
Frank
Re: Console Shifter Plate
do you mean something like this? https://www.heartbeatcitycamaro.com/...-Transmission/
'68 Camaro 454, 4sp
Just 1 More is offline
post #3 of 12 (permalink) Old Aug 21st, 19, 06:36 AM Thread Starter
Apprentice
Justin
Frank,
That is exactly what I am looking for, but it is my understanding that a 67 console is different than a 68. I believe a 68-69 are the same, but a 67 is different. If this is not correct please let me know, but I think the 67 shifter plate has a "V" shape to it and the 68-69 is square. Once again, I could be wrong and please let me know if so. Otherwise, this would be perfect!
Senior31 is offline
post #4 of 12 (permalink) Old Aug 21st, 19, 06:49 AM
Frank
Auto? Manual?
'68 Camaro 454, 4sp
post #5 of 12 (permalink) Old Aug 21st, 19, 06:58 AM Thread Starter
Apprentice
Justin
It is for a manual (4-speed). That would probably help.....sorry about that.
Senior31 is offline
post #6 of 12 (permalink) Old Aug 21st, 19, 07:45 AM
Frank
I can not find a black one for a 68.. that's odd
'68 Camaro 454, 4sp
post #7 of 12 (permalink) Old Aug 21st, 19, 08:01 AM
Robert
Try looking for a 68 or 69 nova. The console was the same as the camaro but the Nova had the black insert and the black gauges.
The insert above I think is labeled wrong, it looks like it should work for what you want to do. It looks identical to the 68/69 insert. The 67 insert is way different. If you are trying to make things a little different but look original you might want to used black gauges also if you have a gauge pod or are thinking of going with a gauge pod.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #8 of 12 (permalink) Old Aug 21st, 19, 08:07 AM Thread Starter
Apprentice
Justin
I tend to agree with you guys. The one in the link does say it is for a Nova as well. I have heard the Nova will work and I find pictures that looks like it will work, but I also find pictures that looking like it is not a square panel. Guess I need to look into getting one to check out.
I was also thinking about going with the black gauges as well. The console I purchased has the original silver ones in it, but that is a simple swap.
Thanks for all the help guys. I will see if I can find a cheap Nova insert to test fit and go from there.
Senior31 is offline
post #9 of 12 (permalink) Old Aug 21st, 19, 08:46 AM
Robert
My 69 console had the nova black insert. I took it out and unfortunately sold it. But it was a direct fit.
Senior31 likes this.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #10 of 12 (permalink) Old Aug 21st, 19, 09:48 AM Thread Starter
Apprentice
Justin
Perfect! Thanks for the info. I will get one ordered.
Thanks again to everyone for all the help!
Senior31 is offline
post #11 of 12 (permalink) Old Aug 21st, 19, 06:58 PM
RDW
Bob
I have a 67 and yes they are different but I had it made on a 3d printer
67 Camaro coupe 327 automatic
78 RS Camaro 350 automatic (sold)
RDW is offline
post #12 of 12 (permalink) Old Aug 21st, 19, 09:09 PM
Red face Re: Console Shifter Plate
https://www.classicindustries.com/pr...s/3947624.html Front piece
https://restorationpartssource.com/s...r-details.html Shift plate for a 67 ?
TJS69 is offline
