interior door stainless trim pieces install - Team Camaro Tech
post #1 of 4 (permalink) Old Sep 28th, 19, 05:10 PM Thread Starter
RJ
Hello guys. Im trying to install the two stainless trim pieces that go on the interior deluxe door trim on 69 Camaro coupe. I bought new door panels, but want to re-use the four stainless pieces. wondering how to locate new holes for the metal tabs to fit into, and don't want to create a disaster, haha. Wondered how you guys went about doing it and making them be in the right spot, tried the ice pick, but that didn't work well. Trying to drill holes is risky, because it would be pretty easy to screw up the carpet on lower door. I know you guys have the answer. Pics or video would be fantastic.
Thank you,
RJ
69 Camaro RS, Dart 406" small block, 11:1 CR, Muncie 4-Comp Cams XR300HR, Dart 215cc aluminum heads, Dart single plane, Hooker 2" ceramic headers Richmond 4:11 rears.
aircavalryveteran is offline
post #2 of 4 (permalink) Old Sep 29th, 19, 04:50 AM
Kevin
KevinW's Avatar
Re: interior door stainless trim pieces install
Using a soldering iron for carpet holes is the most discussed method (carpet is nylon which melts slowly with heat). Repro deluxe panels have a plastic backing, so maybe the iron is they way to go there too. But I have not tried this myself.
Kevin
KevinW is offline
post #3 of 4 (permalink) Old Sep 29th, 19, 07:49 AM
kevin
if you don't have a soldering iron,
I use different size nails and bolts depending on the size hole I want. clamp the nail/ bolt with vice grips and heat using a propane torch . touch the carpet to match the hole
flat tire is offline
post #4 of 4 (permalink) Old Sep 30th, 19, 08:58 AM Thread Starter
RJ
Both good ideas. I happened to see a pro restoration video where the guy used the soldering iron to do his panels. seemed to work pretty good for him, despite the fact that he seems like kind of a duphus, but maybe that is part of his act. Was a goo video any want. After I watched it, I found my soldering iron, and it was exactly what he used. Hence, Ill try it today.
Thank you both for the quick replies. Much appreciated. All you guys rock. The amount of knowledge on this site is amazing.
RJ
