67 Camaro standard front armrest - Team Camaro Tech
 2Likes
  • 1 Post By AJPoremba
  • 1 Post By BRICO69
post #1 of 10 (permalink) Old Oct 13th, 19, 10:03 AM Thread Starter
Apprentice
Alan
Embarrassed to say that I canít figure out the front screw mounting point for my armrests in my 67 Vert. Rear mounting holes are obvious but nothing but air for the front. Is there supposed to be a bracket on the back of the door panel for the front mount? Looked in the Fisher manual etc. and no luck. She has been apart for 8 years and I canít remember this detail. Thanks for the help?
AJPoremba is offline
post #2 of 10 (permalink) Old Oct 13th, 19, 06:19 PM
Re: 67 Camaro standard front armrest
Here's a pic from my 67. No extra bracket. Mounting holes are circled. Do you have an aftermarket door?
my 67' build thread:
allanjs is online now
post #3 of 10 (permalink) Old Oct 14th, 19, 11:32 PM Thread Starter
Apprentice
Alan
Allanjs, thanks for the picture. Iíll take another look tomorrow. The doors arenít aftermarket, one is a donor and one is original to the car
post #4 of 10 (permalink) Old Oct 15th, 19, 08:16 AM
Andrew
Andrew69's Avatar
A couple months ago I was installing door panels and arm rests onto a '67 Firebird. They look the same as what you are working with. This car has reproduction doors on both sides. I found the passenger side door had the holes pre-drilled as Al has pictured above but the driver's side had no holes. And there is no dimpling of hole placement.
I noted the door panels had holes for the armrest mount to sit into. So after the door panel was in place I placed the armrest into position and used a transfer punch to mark the hole locations. Then I removed the door panel, drilled the holes, and reassembled. Be sure the door glass is up before drilling so you don't punch through and tap the glass. You could easily break the glass.
A correctly fitting transfer punch fits snugly, but not tight, into the armrest mounting hole and places the punch mark in the center. Here is an inexpensive set but they're available elsewhere.
https://www.harborfreight.com/28-pie...kaAqJrEALw_wcB
Let us know how this works out for you.
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #5 of 10 (permalink) Old Oct 15th, 19, 01:16 PM
Yeah the one hole that is already in the door looks like it is nearly two inches or better up to high. The advice from Andrew of putting the door panel on an marking the location for the holes is a good idea.
69 Hugger Orange 396 M20 3:31
BRICO69 is offline
post #6 of 10 (permalink) Old Oct 15th, 19, 02:26 PM
Is it possible that door was originally on a deluxe interior car? I don't know but maybe
the deluxe armrests used a different mounting.
post #7 of 10 (permalink) Old Oct 16th, 19, 07:55 AM
Russ
Here's a factory 67 driver's side/LH door, deluxe interior with power windows, FWIW. Armrest is "built-into" the molded door panel, and I can't recall exactly where the screws went.
Petes L48 is online now
post #8 of 10 (permalink) Old Oct 16th, 19, 01:48 PM
Andrew
Andrew69's Avatar
Here's a couple of pictures to help you out. The extended portion of the armrest goes into the precut holes of the door panel. The screws go in at an upward angle. You can see the holes are slightly above the center point of the armrest holes.
The door panel needs to be in its final assembled location then let it guide you in installing the arm rest. You might be able to drill the holes based on this picture providing you respect the center-to-center distance between them.
ID:	229935   Click image for larger version
Skunk Works
Some photos:
Member # 159
Andrew69 is offline
post #9 of 10 (permalink) Old Oct 16th, 19, 04:30 PM Thread Starter
Apprentice
Alan
allanjs, Andrew69, Brico69 and Peteís L84, thanks for all the pictures and ideas. Looks like allanjs was right, the donor door had a deluxe interior (it was stripped down when I bought it 5 years ago). I fitted the new door panel and marked the center of the precut holes and the scribe marks are right where they should be. That extra hole was just driving me crazy(er). Peteís deluxe interior has the same hole so thanks for helping me out! Almost finished (if that ever happens) after 8 years. Thanks again!
Alan
allanjs likes this.
post #10 of 10 (permalink) Old Oct 16th, 19, 04:49 PM
Yeah good deal! Glad you got it sorted out.
AJPoremba likes this.
BRICO69 is offline
