Preferred door seals? - Team Camaro Tech
 1Likes
  • 1 Post By dhutton
post #1 of 12 (permalink) Old Dec 27th, 19, 07:43 AM Thread Starter
Eric
Hi All, I'd like to see if there's a consensus on preferred door seals. I learned there's big difference in options a while back when my trunk would not close.
I need all the seals and felts, including the trim piece that holds the felts. Who should I look at?
Also would like to know what people are using to seal the glass weatherstrip channels to the body. What is working best?
I apologize if I did not get these questions into the correct forum, this seemed more appropriate than Body Shop -
Thanks!
Eric
1968 Standard Coupe, LS1, T56
2007 Tahoe, Z71, Cold Air & Tune
2001 Silverado, Z71, TSP Cam, Cold Air & Tune
really_n0b0dy is online now
post #2 of 12 (permalink) Old Dec 27th, 19, 08:30 AM
Re: Preferred door seals?
The Repops window felts/trim (round) are what I used. Fit well
SoCal805 is offline
post #3 of 12 (permalink) Old Dec 27th, 19, 08:38 AM
Tim
I used a combination of Soffseal and Metro. I can't remember the name of the felts but I do know all but one fit very well.
1969 Camaro - a gift from the brother-in-law build thread
Shannon4570 is offline
post #4 of 12 (permalink) Old Dec 27th, 19, 01:17 PM Thread Starter
Eric
Thanks for the advice - Does anyone have a recommendation one what to use to seal the weatherstrip channels to the top of the window frames?
What goes in this sandwich?
post #5 of 12 (permalink) Old Dec 27th, 19, 01:39 PM
Metro for door and glass seals. Do not use Soffseal or you will not be able to close the door.
PUI for felts.
1959 El Camino project
1957 Buick Caballero project
dhutton is offline
post #6 of 12 (permalink) Old Dec 27th, 19, 01:44 PM
Softseal
post #7 of 12 (permalink) Old Dec 27th, 19, 02:07 PM Thread Starter
Eric
Has anyone used this material for the channel to body seal? Is there something else I should look at?
Name:	Screen Shot 2019-12-27 at 2.04.38 PM.png
post #8 of 12 (permalink) Old Dec 27th, 19, 02:28 PM
I used Metro for weather strip and Repops for the felt on my 67.
Here's a link to a discussion on the material used.
https://www.camaros.net/forums/23-in...p-channel.html
my 67' build thread:
allanjs is online now
post #9 of 12 (permalink) Old Dec 27th, 19, 02:49 PM Thread Starter
Eric
PUI for felts.
Thanks everyone, very, very helpful. Especially the part about adjusting the channel to the glass instead of the other way around.
post #10 of 12 (permalink) Old Dec 27th, 19, 03:32 PM
Iíve used it. Works well imho.
really_n0b0dy likes this.
dhutton is offline
post #11 of 12 (permalink) Old Dec 28th, 19, 06:05 AM
Bruce
PUI for window felts. Last I talked to one of the Camaro vendors, the soft seal has been redesigned so I tried them and the fit fine, not like the ones you had to slam the door. I generally use Metro but they were on back order at the time.
The Camaro Guy is offline
post #12 of 12 (permalink) Old Dec 28th, 19, 09:25 AM
Tim
I have not - I used the 3M strip caulk.
https://www.summitracing.com/parts/t...UaAp0jEALw_wcB
