Door Glass Support Question - Team Camaro Tech
post #1 of 3 (permalink) Old Jan 5th, 20, 09:03 AM Thread Starter
Brett
I am trying to replace the Door glass stabilizer strips and I have two questions. It appears by the Fisher Body Manual that these two parts with the soft fuzzy material attach with the bend turned up? Or do they go on with the curve turned down?
Also, My door inside sheetmetal has a lip that prevents the stabilizer strip to fit. The only way I see it fitting is to cut the metal away either on the stabilizer strip part or cut away the sheetmetal that seems to be in the way from the inside door skin. Hard to tell by pics but hope you can see the problem area. This is a re-pop door.
Brett....
Rockets Up In 2020! Inaugural Launch Date: 9/16/2020 - Vandenberg AFB Pad SLC-2W
Brettallen59 is offline
post #2 of 3 (permalink) Old Jan 5th, 20, 09:22 AM
Vega$69's Avatar
Re: Door Glass Support Question
You can flatten the area on the door so the stabilizer will lay flat.
The way you're holding it is the way it goes.
Vega$69 is offline
post #3 of 3 (permalink) Old Jan 5th, 20, 09:26 AM Thread Starter
Brett
Thanks for the verification John.
Brett....
