67 dash chrome bezels - Team Camaro Tech
 1Likes
  • 1 Post By Bad67355
post #1 of 10 (permalink) Old Feb 14th, 20, 03:54 PM Thread Starter
Quick question how do you remove the bezels on the dash around the cigarette lighter; wipers; ignition; lights?
Do they unscrew is there a specific tool I need to get them off any help appreciated thanks.
67 RS 355sbc 11.76et @ 116mph 1.67 60' Deluxe Parchment interior
Bad67355 is offline
post #2 of 10 (permalink) Old Feb 14th, 20, 06:55 PM
scblucam's Avatar
Re: 67 dash chrome bezels
Been awhile but as I remember they unscrew. I have a set in a box somewhere that need a ladder to get to. We'll see how I feel in the morning.
68 302 M20 - 85 IROC Z
scblucam is offline
post #3 of 10 (permalink) Old Feb 14th, 20, 11:01 PM
Garth
Bezels are held on by the switch. In other words, the switches need to be removed in order to replace the bezels. Probably easiest (for me anyway)to remove the gauge pod to gain access to the backside of the switches.
Cig lighter just has a threaded sleeve on the back to unscrew.
Light switch knob is removed (pulled out) after depressing a button on the side of the switch. You'll see the button with the gauge pod removed.
Ignition switch, take a straightened paper clip and insert in the small hole then turn the lock assembly (with key) ...I forget which way ? I think counterclockwise.
I forget the wiper knob too, I'm pretty sure it has a set screw ? Then nut can be removed.
Garfields Maro is online now
post #4 of 10 (permalink) Old Feb 15th, 20, 06:44 AM Thread Starter
Wow that's a job replacing them and once you have the switches removed how do they separate from the switch?
Bad67355 is offline
post #5 of 10 (permalink) Old Feb 15th, 20, 10:15 AM
scblucam's Avatar
That is probably why I have set that needs a ladder to get to.
scblucam is offline
post #6 of 10 (permalink) Old Feb 15th, 20, 10:37 AM
Garth
The bezels are just sandwiched between the dash and the outer retainer/ nut. The wiper, light switch and ignition switch doesn't have to be completely removed. The Cig lighter does have to be removed.....IIRC
It's fairly easy after the gauges are removed.
post #7 of 10 (permalink) Old Feb 15th, 20, 12:38 PM Thread Starter
Thanks Garth I have bought them from Rick's Camaro and I will give it a shot.
Garfields Maro likes this.
Bad67355 is offline
post #8 of 10 (permalink) Old Feb 16th, 20, 07:14 PM
r_w
Robert
Ignition switch nut uses this tool a "Camaro Ignition Switch Bezel Retaining Nut Installation Tool." But you also have to do the paper clip trick, if you internet search that you can find more details.
______________
Life is too short to drive cars that suck.
'67 Convertible
'68 Coupe
r_w is offline
post #9 of 10 (permalink) Old Feb 20th, 20, 06:09 PM Thread Starter
So this tool only takes the bezel off for the ignition switch only or will it work for others as well?
Bad67355 is offline
post #10 of 10 (permalink) Old Feb 23rd, 20, 07:45 PM
r_w
Robert
Only the ignition switch. I don't think a special tool is required for the others if my memory is correct.
______________
'67 Convertible
'68 Coupe
r_w is offline
