1968 Gauge Cluster Cloudiness - Team Camaro Tech
 1Likes
post #1 of 18 (permalink) Old Mar 30th, 20, 10:47 AM Thread Starter
Hello all,
First post, been a long time lurker. My mostly stock 68 has very cloudy gauge clusters that I am trying to clean up, what is the best way to get these cleared up without having to take the housing completely off and disconnect the cluster?
I am hoping that the cloudiness is on the outside of the glass/plastic and not the inside, I attached pictures to the post to show you what I'm looking at.
Thanks in advance.
Name:	dash cluster 1.jpg
GlacierBlue68 is offline
post #2 of 18 (permalink) Old Mar 30th, 20, 10:55 AM
Robert
Re: 1968 Gauge Cluster Cloudiness
Have you tried using soapy water first? If that doesn't work don't be afraid to take the gauge cluster apart. It is only a few screws. It is pretty easy and doesn't take very long.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #3 of 18 (permalink) Old Mar 30th, 20, 11:10 AM Thread Starter
I tried soapy water and even olive oil, but it doesn't seem to come off.
I also looked at the AIM for the part, looks like there are a good amount of connections on the back, does the cover come off the actual gauges or does the whole assembly have to come off? Sorry, I'm a motorcycle guy, a lot of this stuff is new.
post #4 of 18 (permalink) Old Mar 30th, 20, 11:40 AM
Robert
On my 69, you can remove the gauges and then access the lenses. I can leave everything connected, but it's obviously a littler easier to work on if you remove the connectors. I am assuming it should be a similar process with your 68. If you can get the lenses out you can probably just use a headlight polishing kit, or something similar.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #5 of 18 (permalink) Old Mar 30th, 20, 01:18 PM
Garth
You could try a plastic polish such as Novus https://www.amazon.com/NOVUS-PC-10-P...s%2C272&sr=8-3 , otherwise you'll have to disassemble. It's not too difficult. Repro lenses are readily available...https://www.heartbeatcitycamaro.com/...-Without-Tach/
Garfields Maro is offline
post #6 of 18 (permalink) Old Mar 30th, 20, 05:57 PM
My lens was not as bad as GlacierBlue68's but was cloudy and scratched enough that I didn't want it going back in a restored car looking that way.
My gage cluster was already apart so it was easy to work on the lens. I used three steps on mine. I started with Novus #3, then went to Novus #2, and finished with Mequiars's PlastX. It came out like new. It would have been hard for me to do with the lens installed....getting the polish all the way to the edges of the lens and not getting any of it on the housing. I don't have a before picture, just the attached after picture.
Before I did this, I tried two reproductions. They were both OER. I bought one and it was terrible. I sent it back and got another one. The second one was just as bad. That was about five years ago though. Maybe there's better stuff out there today.
1968, 327 210 HP, Power Steering, Power Disc Brakes, Custom Interior, 4 Speed, Console, Gauges, Tilt Wheel, Speed Warning, Fiber Optics, 10 Bolt 3.55 Posi Rear end......Owned since 1978.
daven1256 is offline
post #7 of 18 (permalink) Old Mar 30th, 20, 06:19 PM
Pretty much a plug and play deal....not really hard.
I think the hardest part for me was lowering the steering column ? (not much really)
68 Camaro~LSx ~all motor
post #8 of 18 (permalink) Old Mar 30th, 20, 08:48 PM
John Paige
Mothers mag & aluminum polish followed up by plexus does a nice job. Also works well on tail lights, parking lights etc.
67 RS SS Conv, yes it's real
NOT A TA is offline
post #9 of 18 (permalink) Old Mar 30th, 20, 09:09 PM
Garth
I had to disconnect the speedo cable first as it wasn't long enough after partially pulling the carrier assembly out (to disconnect). Luckily it was just finger tight (as it should be) or it could've been a beotch.
I still have the original lens as well. No experience with the repros...
post #10 of 18 (permalink) Old Mar 31st, 20, 08:03 AM Thread Starter
Thank you for the quick replies.
I am going to try the PlastX route first, and see how clear I can get them without having to take off the housing. At this point I have plenty of time on my hands since we are in lock-down here in Chicago, so I don't mind.
If it turns out clear, I'll be sure to post a before and after, once the OCD wears down.
post #11 of 18 (permalink) Old Mar 31st, 20, 08:04 PM
r_w
Robert
Time is a good thing, right? Don't be afraid to pull the cluster, It's not hard. I pulled it on my '68 while working through some wiring issues. Wish I had polished like davn1256, that looks like new!
______________
Life is too short to drive cars that suck.
'67 Convertible
'68 Coupe
r_w is offline
post #12 of 18 (permalink) Old Apr 1st, 20, 04:38 PM
Make sure when putting the cluster back in that the upper center screw is tight. It is a ground and things get crazy if it is not tight enough.
1968 Z-28 Black stripes on white, 350, M22, 12bolt. WIP since August 1979
jimnecci is offline
post #13 of 18 (permalink) Old Apr 1st, 20, 07:24 PM
Try Flitz. Just used it on my speedo and tach lens to remove scratches with success.
jcabuilder is offline
post #14 of 18 (permalink) Old Apr 2nd, 20, 12:25 PM
Bruce
Most anything with a little grit, followed with a glaze or polish. . . . .even toothpaste! While you have the lens off, take a Q-tip with armor all and clean up the face of the gauges then buff with a micro cloth and if your lucky paint some modeling orange Florissant on the needles.
The Camaro Guy is offline
post #15 of 18 (permalink) Old Apr 2nd, 20, 04:51 PM Thread Starter
I wanted to make sure I delivered.
Amazon delivered my Plast-x today and I went out with a rag and microfiber cloth and went to town without taking it off.
Incredibly surprised at how well it worked, took about 45mins, but so happy with the results.
Once my fingers work again, I'll finish up the last bits of cloud, but thanks again to everyone who chimed in.
68 Sport Coupe | 350 SBC | TH350 |
