Center Clock 69 - Team Camaro Tech
 1Likes
  • 1 Post By frog7151
post #1 of 6 (permalink) Old Apr 3rd, 20, 03:39 PM Thread Starter
Center Clock 69
Hi i am looking for a centre Dash Clock for a 1969 Camaro and or the Template to cut the dash Thanks
Kelcel is offline
post #2 of 6 (permalink) Old Apr 3rd, 20, 03:42 PM Thread Starter
Dash Clock 69
Hi i am looking for a template to cut the Center Dash where the clock would go on my 1969 any ideas would be great Thanks
Kelcel is offline
post #3 of 6 (permalink) Old Apr 3rd, 20, 06:06 PM
Donnie
Re: Center Clock 69
The dimensions are in the 69 AIM.
Camaro Donnie
1969 RS/SS Black 4 Speed Camaro Coupe
390 Gears with 410 CI small block
Camaro Donnie is offline
post #4 of 6 (permalink) Old Apr 3rd, 20, 07:20 PM
shawn
Re: Center Clock 69
Hope this helps
Kelcel likes this.
frog7151 is offline
post #5 of 6 (permalink) Old Apr 3rd, 20, 09:09 PM Thread Starter
Re: Center Clock 69
Originally Posted by frog7151 View Post
Hope this helps
Thanks !!!
Kelcel is offline
post #6 of 6 (permalink) Old Apr 4th, 20, 07:33 PM
Donnie
Re: Center Clock 69
You can get the AIM from Camaro Tech Group. If you have th plastic lens hold it up against the middle and scribe the lines onto the dash holder. I cut mine with a hand saw and kept the middle piece that has camaro on it but I do not know why I kept it. After getting close use a Dremel tool to help you get final fit. Use a square to get one side straight and then fit the other side.
Camaro Donnie
