69 Camaro driver seat won't fold down? - Team Camaro Tech
post #1 of 7 (permalink) Old May 11th, 20, 09:08 AM Thread Starter
James
The lever on the back of my 69 Camaro driver seat doesn't work, I am unable to fold down the seat so I can let passengers in the back.
Any step by step instruction how I can go about fixing this?
James Neal is offline
post #2 of 7 (permalink) Old May 11th, 20, 09:20 AM
Re: 69 Camaro driver seat won't fold down?
be easier to work on if you remove the seat. The release lever may be stuck on something or broken so once seat is out remove the screws and look
SoCal805 is online now
post #3 of 7 (permalink) Old May 11th, 20, 11:14 AM
scblucam's Avatar
Unless they are kids they don't belong in the back seat of a moving Early Camaro.
68 302 M20 3:73 - 85 IROC Z - 82 Honda CB900C
scblucam is online now
post #4 of 7 (permalink) Old May 11th, 20, 12:25 PM
Robert
There should be a small screw on the lever to remove it and the hard plastic backing should lift up and pop off. If you have headrests you may have to lift that up out of the way, or slide it all the way out. You may be able to get to it from the passenger side, but completely removing the seat may be easier.
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
post #5 of 7 (permalink) Old May 11th, 20, 08:14 PM Thread Starter
James
Thanks I'll give that a try.
post #6 of 7 (permalink) Old May 12th, 20, 04:44 AM
Not going to pop off because the seat back is retained by two screws on the bottom.
Call for restoration and custom paint scheduling:
Sauron67MM is offline
post #7 of 7 (permalink) Old May 12th, 20, 06:46 AM
Robert
Yes!! I remembered those after I posted, and I was going to update, but got distracted! (Something shiny!)
My bad! Good catch Scott!
AKXtreme
69 Camaro L48 SS350
M20 4spd
akxtreme is offline
