Cleaning and Lubing Window Mechanisms - Team Camaro Tech
post #1 of 4 (permalink) Old May 23rd, 20, 10:54 AM Thread Starter
Eric
Hey All, I'm finally getting around to working on my doors and quarters. I'm pulling out all the mechanisms so that I can dynamat the backside of the door-skins and quarters. While out I'm going to degrease all the parts and replace the rollers.
What kind of lubricant should I use on the window crank pinion and gear? What should I use on the rollers and tracks?
And... What do you guys use as a spanner for the window roller nuts?
Thanks!
1968 Standard Coupe, LS1, T56
2007 Tahoe, Z71, Cold Air & Tune
2001 Silverado, Z71, TSP Cam, Cold Air & Tune
really_n0b0dy is offline
post #2 of 4 (permalink) Old May 23rd, 20, 12:06 PM
keith
X-77 keith's Avatar
I use super lube on the window parts. There is a special socket for the roller nuts, or you can grind down one of your sockets.
X-77 keith
X-77 keith is online now
post #3 of 4 (permalink) Old May 23rd, 20, 12:57 PM Thread Starter
Eric
Re: Cleaning and Lubing Window Mechanisms
The socket idea worked perfectly and I have found the Super Lube nearby. Thanks Keith!
post #4 of 4 (permalink) Old May 23rd, 20, 01:04 PM
keith
X-77 keith's Avatar
Very good.
X-77 keith
