75 camaro rear into 68 camaro? - Team Camaro Tech
Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
post #1 of 2 (permalink) Old Sep 14th, 01, 06:36 PM Thread Starter
will a 1975 10 bolt camaro rear bolt in to a 68 camaro without moving the spring perches?
i have multi leaf springs in my 68.
thank you in advance for your help!
alan peters is offline
post #2 of 2 (permalink) Old Sep 14th, 01, 07:10 PM
Nick
Rarerat's Avatar
No. a second generation Camaro rear end is 1 inch wider than a first gen car. I have used them in First gens before but you will have to move the spring pads in. Also the rear end will be a 1/2 wider on each side, but if you are using 7 inch rallys its not a problem.
i hope this helps,
Nick
69 Z/28 X77 D80 81000 original miles,DZ 302, M-21, BU 373 Rear End, ZL-2 Ducted Hood, Daytona Yellow, Black Deluxe, Tilt, Factory AM/FM, Console Gauges.
Rarerat is offline
