67 air conditioning - Team Camaro Tech
Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
post #1 of 3 (permalink) Old Oct 11th, 01, 12:08 PM Thread Starter
How difficult is it to remove the air conditioning unit from the firewall and still retain a functioning heater? Is there a lot of sheet metal fabrication or is there a blower and cowl assy. from another G.M. car that will fill the hole left in the firewall? The air conditioning does not work and is too expensive to be rebuilt, and I thought the engine compartment would look much cleaner without all the air conditioning equipment. Any advice would be appreciated.
Tdks
tdks is offline
post #2 of 3 (permalink) Old Oct 11th, 01, 06:39 PM
Joe
Talking
I don't know how much this will help, but my 69 has had the AC box cut off flat and glassed over to mount the coil and ignition box. If you leave the rest of the controls intact, the heater, defroster and vacuum controlled vents will still work.
It will take a bit of effort, but if done right it looks pretty good. Cleans up the engine compartment and the heater still works.
You can see it in my sig if you look close.
joe
69 SS396 Resti-Clone
WCA Member
[email protected]
69 Pics http://albums.photopoint.com/j/Album...559&a=11674961
Joe G is offline
post #3 of 3 (permalink) Old Oct 12th, 01, 01:43 AM
Daniel
Those parts are worth some money. I would be careful when taking them off. Have you considered changing the system over to use R134A? I did this and it works fairly well.
Daniel
67 RS/SS 350 2004R (owned since 81)
97 V6 5-speed Coupe (work car ordered new)
My Camaro
67ss350camaro is offline
