67 wiper motor - Team Camaro Tech
Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
post #1 of 4 (permalink) Old Oct 20th, 01, 06:13 AM Thread Starter
I just installed a BB in my 67 camaro. I have roller rockers with tall valve covers and now the wiper motor will not fit as the motor section hits the valve cover. It will fit it I rotate the wiper motor a half turn to the left and drill new mounting holes, however the control arm which connects to the wiper blade arm hit the bottom of inside valley pan. Anyone got any good ideas to help me? I know I can't be the first one to install a BB with tall valve covers in a 67. Any help is greatly appreciated.
Thanks, Gene
ssz28_41 is offline
post #2 of 4 (permalink) Old Oct 20th, 01, 06:42 AM
169indy's Avatar
Lightbulb
I while back at the track in Bremerton Washington I saw a car with a similar problem. He had installed a wiper motor from a 95 S10 Chev truck. It was a lot thinner and bolted in using the same bolt pattern. I believe the only mod necessary was to fabricate a different "ARM" that connects the motor output shaft to the wiper arm linkage in the cowl area. Again, I have not tried this just saw what someone else had come up with. Good luck
169indy is offline
post #3 of 4 (permalink) Old Oct 20th, 01, 10:36 AM
William
William's Avatar
Did you use bb frame brackets & crossmember?
William is offline
post #4 of 4 (permalink) Old Oct 20th, 01, 02:52 PM Thread Starter
169indy,
Thanks for the idea. Should be able to find an old wiper motor from a 95 S-10 in our local junkyard to check out. Sure would be nice to find out what mod if any had to be done to the control arm.
ssz28_41 is offline
