67 bucket seat position ? - Team Camaro Tech
Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
post #1 of 2 (permalink) Old Oct 21st, 01, 02:52 AM Thread Starter
before I recovered my seats in the 67 I had plenty of leg room,but now I seem to be cramped.
the seats don't seem to go back as far now .
are the tracks different from side to side or have just gotten fatter ???
I used to have to pull forward one click but now it's back as far as it will go !------------------
camaro's for ever!!!
67 327 11:1 4spd.
70 454 400thm 10 posi
my camaros
[This message has been edited by 4 speed (edited 10-21-2001).]
4 speed is offline
post #2 of 2 (permalink) Old Oct 21st, 01, 07:53 AM
Gary
I have my tracks out, and unbolted fron the seat bottom, so I just messed with it a little, to see what might be screwy. You can't mix up the outer track, since that has the release (pull back to release) However, if you reverse the inner ones, you will reduce the maixmum movement rearward, by about 1". Try unbolting the inside track, and reversing it 180 degrees. Inside track on both sides are identical (not mirror) It appears that there are two bolt holes in the floor of the pass side to compensate for the reversed inside track, not sliding back as far.
Unreal is offline
