Super T-10 - Team Camaro Tech
Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
post #1 of 2 (permalink) Old Oct 31st, 01, 08:57 AM Thread Starter
I was on the sight www.smokemup.com (thanks for the info) and I noticed that there were 8 different Super T10s. Does anyone know if you can switch gear sets to another gear set.
I would love to get the "U" ratio which has the low 3.44 1st gear.
I could put a higher gear rear end, still get off the line good, and still have good top end cruising. It would be like having overdive.
Tony
obnoxious 67 camaro under construction. TH350/383 stroker w/ aluminum Edlebroc RPM heads,cam, and carb.This is a "Daily Driver" that need A LOT of work. But has new quarters and new floor pans.
OBNXUS67 is offline
post #2 of 2 (permalink) Old Oct 31st, 01, 09:08 AM
Actually that is the most common one you will find. Take a look at the swap meets. You don't want to buy a gear set it's scarry.
oger is offline
