overdrive in a 69 - Team Camaro Tech
Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
post #1 of 5 (permalink) Old Nov 6th, 01, 08:27 AM Thread Starter
I have a 69z28rs Iam going to put a 700r4 I already have it built. I need to know were I can get the shifter with the right patteren or do I modify the shifter I already have. Also will this trans work with the 400 crossmember I have. And do I need any special shifter brackets to get the shifter to work with cable that i have any other comments are welcome thanks Robert
twosxe1 is offline
post #2 of 5 (permalink) Old Nov 6th, 01, 08:36 AM
Cool
Contact www.shiftworks.com for a kit to use original automatic shifter. Your TH-400 x-member will need to be modified to work. You will also need A t.v. cale and adapter to your carb. Also needed is a kit to lock-up your torque converter. Your driveshaft will need to be shortened as well. You might want to check out www.bowtieoverdrives.com for more info.
69 Camaro Z28 "clone" - 327 AT
"461" camel back heads,
edelbrock, hooker, ultradyne,
TRW etc.
700R4 TPI transmission
[This message has been edited by TJS69 (edited 11-06-2001).]
TJS69 is online now
post #3 of 5 (permalink) Old Nov 6th, 01, 10:22 AM
DjD
DjD's Avatar
You've been given some good resources to draw from but your conversion from a 4 speed is going to be more intailed than someone converting from an existing auto vehicle. You will also find your 302 engine isn't going to like the automatic very well. You may find it to be quite a dog on the street...
...Dennis
"The '69, the '96 & the club"
DjD is offline
post #4 of 5 (permalink) Old Nov 6th, 01, 11:15 AM
check out summit racing, online or order a catolog. good luck
ZMANIA is offline
post #5 of 5 (permalink) Old Nov 8th, 01, 06:10 AM Thread Starter
GREAT INFO Thanks
twosxe1 is offline
