1986 IROC - Team Camaro Tech
Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
post #1 of 11 (permalink) Old Nov 21st, 01, 09:27 AM Thread Starter
Cool
I have a 1986 Camaro IROC. I was wondering what I should do to the 1999 GM Crete Engine that is in it already to make the car faster? I was thinking about getting my heads ported and some tracktions bars. What do you think? Thanks Nevin
NevinKez is offline
post #2 of 11 (permalink) Old Nov 21st, 01, 09:40 AM
Get the nitrous kit part number: NOS-05001. it is a set shot of 125 hp. with that and some rear shocks and maybe some traction bars----your car should hit high 12s.
my cousin has a --- 86 IROC with a 350 crate motor,3.73s, flowmaster, T-tops, shift kit, Holly 650 carb., automatic, 94 Trans Am seats--- i just do the research for him.
N8Miller is offline
post #3 of 11 (permalink) Old Nov 21st, 01, 12:08 PM
which crate motor?
the gmpp 330horse?
or the 250horse goodwrench?
either way, cant go wrong with a comp camp x/e 268
Joshua Leslie is offline
post #4 of 11 (permalink) Old Nov 21st, 01, 12:12 PM
joshua,
its the gmpp 330hp one. where can we find specs on that motor (cam duration, head info, etc). and what is the comp cam thing your talking about? i know comp cams have intake for mustangs, is that an intake or a cam?
N8Miller is offline
post #5 of 11 (permalink) Old Nov 21st, 01, 12:48 PM
i secong the 125shot of nitrous. dont listen to all crap about nitrous being dangerous. its just as safe as a supercharger or turbo. both can blow your motor if not used properly. just read all the recomendations and beef up your fuel system. youll be glad u did
The pike.net
01 MR2 Spyder<~~~~~~~~~~~~~>68 RS/SS 396
[This message has been edited by jvolk81 (edited 11-21-2001).]
jvolk81 is offline
post #6 of 11 (permalink) Old Nov 21st, 01, 12:51 PM
Here are the specs of the motor.
330 HP @ 5000 RPM, 380 ft.lbs. Torque @ 3800 RPM (Max. Recommended RPM: 5500)
9.1:1 Compression Ratio
Cast Iron 4-Bolt Block with One-Piece Rear Main Seal
Nodular Cast Iron Crankshaft
Cast Aluminum Pistons
PM Steel Connecting Rods
Cast Iron 64cc Chamber Vortec Cylinder Heads with 1.94'' Intake and 1.50 Exhaust Valves
Dual Pattern Cam, Lift: .435'' Int. / .460'' Exh., Duration @ .050: 212į Int. / 222į Exh.
1.5 Ratio Rocker Arms ''
When hot rod or chevy magazine put a comp cams x/e 268 with a edelbrock rpm manifold, it made almost 400 horse!
specs for that came are:
Grind: 268
Lift: .477''/.480''
RPM Range: 1600-5800
post #7 of 11 (permalink) Old Nov 21st, 01, 01:29 PM
im really impressed by that cam. but is it one of those $300 ones that dont come with lifters or is it resonably priced? and what heads could we swap them out with (edelbrock, etc...)? they are iron and the IROCs are heavy cars, so some weight reduction would be great by going with a set of aluminum heads.
N8Miller is offline
post #8 of 11 (permalink) Old Nov 21st, 01, 03:27 PM
Summit sells the extreme energy line(268XE included) for ~$97. Add a set of lifters for $30-$40 and your ready to rock.
As far as heads, the vortec heads on your motor are pretty good. But if you want aluminum, the Trick Flow 23* seem to be the hot ticket for budget aluminum heads @ ~$900 a set complete. And they outperform the vortecs, sportsman II's, and Dart iron eagles out of the box.
-Joe
79' Z28 4-spd- built 355, TRW 10:1 forged flat tops, WP SportsmanII heads, Crane Energizer 230/230 duration .480"/.480" lift, Edelbrock Victor Jr., Holley 750cfm, Dynomax headers, dual 3" flowmasters 3.73 Posi 10-bolt
joesmith69 is offline
post #9 of 11 (permalink) Old Nov 24th, 01, 05:54 PM
thanks everyone. but we were wondering----how about a set of AFR heads. They are real nice, anyone like them?
N8Miller is offline
post #10 of 11 (permalink) Old Nov 26th, 01, 11:48 AM
Not steer you away from here...
But for thirdgen tech you really must go over to www.thirdgen.org
Its easily the largest and best resource for info. on thirdgens.
Timmys88Z is offline
post #11 of 11 (permalink) Old Dec 1st, 01, 01:08 PM
how are those pistons gonna like about a 125 shot of NOS???
and were gonna get that cam for or right after Xmas, so that will make some nice HP gains.
N8Miller is offline
