96 lt 1 in 68 camaro - Team Camaro Tech
Tech 2001 General Tech questions from 2001
Replies ONLY, no new topics.
post #1 of 3 (permalink) Old Jan 1st, 02, 10:29 AM Thread Starter
how can i use the factory lt 1 harness in a 1968 camaro? and how can i make the speedometer and mechanical gauge work?
ddoug is offline
post #2 of 3 (permalink) Old Jan 2nd, 02, 06:26 AM
Try to
red69camaro is offline
post #3 of 3 (permalink) Old Jan 2nd, 02, 06:36 AM
I used the stock wiring harness. You can break open the firewall connector and clean off the waxy stuff that holds the wires together. Jags that run sells a reluctor gear and the mechanical setup for the tranny. their website will tell you everthing you need to know, Their book sucks when it come to and LT1 swap, its more for the older tpi swaps. Also, subscribe to http://www.alldatadiy.com/ for the donor car, its $15/year and gives you a great deal of info on the wiring and sensor particulars. I found it invaluable. If you have any questions, just ask,
