LS swap w/6L80E in a 68 with front bench seat - Team Camaro Tech
post #1 of 7 (permalink) Old Mar 18th, 16, 02:32 AM Thread Starter
Apprentice
Wes
Does anyone know if a 6L80E will fit with a front bench seat? Are tunnel mods needed, and if so, will they interfere with the bench seat?
Also, do any of the long tube swap headers work with a column shift (probably similar issue for a manual with a cross shaft)?
Recommendations would be appreciated.
Wes
1968 Camaro (My son's)
1967 Chevy SWB Fleetside
1962 Corvette
1957 Chevy 150 2 Dr Sedan
wesmigletz is offline
post #2 of 7 (permalink) Old Mar 18th, 16, 05:06 AM
Jason
blue89bird's Avatar
Re: LS swap w/6L80E in a 68 with front bench seat
I can't offer first hand knowledge, but my guess is a 6L80 is definitely going to require tunnel mods. How much will largely depend on what motor mounts and brackets you end up using. You'll likely have to modify the bottom seat frame around any tunnel mods.
As for column shift, I'm using hooker headers (and everything else) for my ls swap and they state you can keep it with an aftermarket linkage from lokar. I'm going with a manual so I never looked into it much.
Jason
2009 CTS-V - 1968 Camaro 327/M20 Sequoia Green
blue89bird is offline
post #3 of 7 (permalink) Old Mar 18th, 16, 06:54 PM Thread Starter
Apprentice
Wes
blue89bird, thank you for the feedback. After speaking with PSI today, I found out that my 6L80E won't work with our LS2 because of the 24 reluctor wheel. We're currently running a MY6/A833 4 spd manual behind a mild 350. I may try to keep it, or could go with a 4L60E and re-use the column shifter. It looks like these headers will work with either.
Hooker Super Competition Headers 2288-1HKR - Free Shipping on Orders Over $99 at Summit Racing
1962 Corvette
post #4 of 7 (permalink) Old Apr 3rd, 16, 05:14 AM
Jason
Wes, I have a 69 with an LSA and a 4l80e. I kept mine column shift. I used the lokar linkage and I have Hooker long tube headers, works fine.
steery is offline
post #5 of 7 (permalink) Old Apr 5th, 16, 06:12 PM
Tony
Any mods to the trans tunnel?
Tony
Follow my current Camaro project builds...
1967 Coupe (Sold)
1968 Convertible
1969 Convertible
bondora68 is offline
post #6 of 7 (permalink) Old Apr 17th, 16, 05:40 AM
Jason
No, no tunnel mods needed
steery is offline
post #7 of 7 (permalink) Old Apr 18th, 16, 07:00 AM
Todd
Don't confuse the 2288HKR Hooker headers with those referenced by steery, as they feature older design geometry that is not compatible with the 4L80 transmission. You can find the newer headers that steery used on the Holley website under the 1st-gen F-body LS swap system pages.
toddoky is offline
