VSS needed ?? LS Swap - Team Camaro Tech
post #1 of 5 (permalink) Old Mar 27th, 16, 04:03 AM Thread Starter
DT
Donny
DT's Avatar
I just read Jeff's (working 24/7) post regarding his VSS issue. I will be using a TKO 600 5 speed and have the option to run a mechanical speedo or VSS/electronic. I'm not sure a VSS is needed ??? Anyone running an LS3 without the VSS ??? I think John did a swap for a buddy with the TKO and no VSS.?
DT is offline
post #2 of 5 (permalink) Old Mar 27th, 16, 05:05 AM
Jeff
Re: VSS needed ?? LS Swap
I'm in the process of installing gauges as we speak, I had the same option, I went with the mechanical mainly because it was already set up for mechanical. Although I'm not running an ls, is that signal needed for your application?
Jeff
- 400 Dart Little"M", SRP 10.2:1, 4340 Scat rotating Assy, Solid Roller, AFR 210 Eliminators, Jesel shaft rockers,Super vic, Prosystems 847CFM, Tko600, 12 bolt 4:10 Eaton posi W/ Strange Hy-Tuf race axles and eliminators.
Best E.T. (11.96 @ 118.06) N/A
Classic Copper 4 Spd
jcdubs is offline
post #3 of 5 (permalink) Old Mar 27th, 16, 07:14 AM
Vega$69's Avatar
Both my buddy's LS3/480 and my 525 use the GMPP control system and ECU.
His has the original speedo and cable to the TKO600. Mine has Autometer Electric speedo T56.
My car will not start and run without the VSS hooked up. For his I don't remember if we hooked up the VSS wires on the harness to the tranny although I believe I did.
I would hook it up
69 SS396 Cortez Silver(SOLD)
69 Z28(Sold)
69 Pro Tour - LS3/T56
(SOLD)
69 Pro Tour - LS7/T56 (SOLD)
69 RS Clone 427/TH400 (SOLD)
67 RSZZ502/5 Speed (SOLD)
Vega$69 is offline
post #4 of 5 (permalink) Old Mar 27th, 16, 09:38 AM Thread Starter
DT
Donny
DT's Avatar
I would hook it up
OH good to know John, Thank you very much.
DT is offline
post #5 of 5 (permalink) Old Mar 27th, 16, 01:51 PM
Garth
The GMPP harness had it so I used it, no issues. From reading things here and John saying it's required I would say you need it.
1969 Camaro SS 350 LeMans Blue
2015 Z/28 - Red
2 x 1967 R/Tís
1977 Power Wagon
1978 Liíl Red Express
69L48Z27 is offline
